Aftermarket temp gauge
I thought I would ask this here....88 f350 7.3 .
My temp gauge seems to have quit working, fuses seem fine, new thermostat seems to be working as it should, new temp sending unit, thought the new one I purchased was a dud so bought another one, still no go. I did the wire to ground test, still nothing.. It could be the gauge I guess....is there an aftermarket temp gauge that would work?
This is the coolant temp gauge that I installed in my 86 f250:
https://www.summitracing.com/parts/atm-2607/overview/
I put the temp sensor in a coolant port on the head between cylinders #6 and #8. I also used the coolant port on top of the water pump for my electric fan. Either port will work for a temp sensor. Here's a thread I started when my truck had a bad thermostat:
https://www.ford-trucks.com/forums/1...erheating.html
I'd just go mechanical and never look back, factory gauges were never accurate. It'll come with a bung to replace that factory sender and you only need power for the light.
They do offer electric gauges that can utilize the factory sender. I had one off of fleabay called a dragon. It was a cheap Chinese one but worker really well until I went full mechanical for both the temp and oil pressure.
