The pipe coming off the bottom radiator hose going to the block for supply water, does anybody know where i can get that tube or what
they call it to try and find the tube? Its like 20 inches or so long that screws into the side of the block under the freeze plugs.
The other end clamps onto the bottom radiator hose.
There are a few pieces that make up the system. The piece that goes in the lower radiator hose should look like this
The small inlet would connect to a rubber hose that leads to the next metal tube. There are some good pictures of a complete system taken from various angles here.
I have a good used one like the one Chad posted. PM me and we can work something out if that's what you're looking for.
Thank you for responding. I have that part you had in the picture.
There is a hose/tube running from the small inlet in the picture all the way to the block where it screws into the block.
Thats the part i need, It has a metal tube that is spliced by a rubber hose and clamps.
