E-Lock and boat ramp
Old Sep 18, 2019 | 04:35 PM
ThumbsUp's Avatar
ThumbsUp
Originally Posted by seventyseven250
That cuts me deep.
I've heard it said that you only kidd the people you like.
Old Sep 18, 2019 | 09:04 PM
Mikelikesit's Avatar
Mikelikesit
If your pulling out straight theres no need to unlock or shift out of 4x4. If the lot is sand or dirt theres little reason either. If its pavement and your pulling the weight of a boat and you try to turn sharply the truck will inform you that your screwing up and youll remember to shift out.
As far as the e locker, I bought it on my truck because Id rather have and not need as the previous reply stated. That said. If you know your on a slick ramp lock it in. Theres more risk to your driveline losing and then regaining traction than if your locked in and never slip... even if you do need to turn a little.
Old Sep 18, 2019 | 10:01 PM
HRTKD's Avatar
HRTKD
My truck in 4Lo isn't jerky at all. I put it in gear and it starts moving without any action on the accelerator pedal. This is with an 11K trailer going up a slight incline to get out of my storage spot. Since the storage lot is dirt/gravel, I take that opportunity to briefly exercise the four wheel drive system.
Old Sep 19, 2019 | 12:06 AM
'12 Duty Super's Avatar
'12 Duty Super
I say order it. It's better to have ……..(what everyone else has already said) From a personal note I have a 8500lb+ boat as well and I have never** had to use the E locker or 4WD pulling my boat in or out. That was with my 2012 F250 and my new 2019 f250. My 2007 f150 was a different story all together. I have put my boat in at no less then 50 different ramps throughout the country and never had a need to use the locker or 4WD. This is also with my wife doing the driving most of the time since she won't drive the boat on the trailer. Even on wet ramps I have never had a problem with tire spin except the occasional slight slip. Just don't mash the pedal to the floor and your fine but order the locker just incase.
John
** There was one time when I loaded it from the shoreline and there was no ramp. It was an emergency situation and had to back it into the lake in the mud and it took 4WD and a lot of foul language to get it out.
Old Sep 19, 2019 | 09:01 AM
WyoBull's Avatar
WyoBull
Just like in 4 wheel drive, if you lock in your rear differential, you also do not want to turn the truck with it engaged. I would definitely order it as was said above, better to have it and not need it than...
Then, teach your wife how to correctly use it and you will be fine. I can tell you that I have electronic locking rear diffs on my truck and I have used it a number of times where anybody else would have had to put it in 4 wheel drive. It is great when you need it.
Old Sep 19, 2019 | 09:05 AM
seventyseven250's Avatar
seventyseven250
Well, you aren't going to hurt anything leaving it locked at low speed, it's just doesn't turn well and it will feel funny.
Old Sep 19, 2019 | 09:59 AM
Tom's Avatar
Tom
I would say the same about four-wheel-drive. I've heard people insist that you're bound to break something by doing that, but I've never seen or heard of that ever happening. The powertrains in these trucks are extremely robust.
Old Sep 19, 2019 | 10:19 AM
Sonny Crockett's Avatar
Sonny Crockett
I'd get it for other situations but you shouldn't need it on a textured ramp.
Old Sep 19, 2019 | 10:47 AM
wicked 2018's Avatar
wicked 2018
Originally Posted by George C
Does a non E-locker just drive one wheel?
I’m placing an order this week for a 2020 CCSWB Limited. We launch a 27’ boat weighing about 8-9k total.
Would a standard rear end pull it out without spinning on a textured ramp? My current truck has a limited slip and never spins. I would “assume” it would spin a little even before the LS kicks in..
My wife drives the truck at the ramp, and I would rather not have her behind the wheel on dry pavement with the 4X locked.
If it’s not needed, I’d rather not order it.
Thanks.
If you are custom ordering the truck, just get it. It's a cheap option when building but expensive to add once you own it.
Old Sep 19, 2019 | 12:39 PM
sky Cowboy's Avatar
sky Cowboy
95% of the time I tow, launch, and retrieve my boats with a rear wheel drive only pickup, use the E-locker, and never have any problems.
Old Sep 19, 2019 | 05:56 PM
82_F100_300Six's Avatar
82_F100_300Six
if I back the trailer down into the water with the e-locker on and turn the truck off is the rear end still locked while the truck is off?
Old Sep 19, 2019 | 06:06 PM
Sport45's Avatar
Sport45
No, but if you set the park brake it doesn’t matter. It will re-lock when the key is turned back on unless you turn it off.
But then I’d never shut a vehicle down if it’s deep enough for the exhaust to be bubbling.
Old Sep 19, 2019 | 06:42 PM
  #28
sky Cowboy's Avatar
sky Cowboy
Why would you want to shut it off to begin with.
Mind you nowadays my wife is the one backing it down the ramp 3/4 of the time.
We have it down to a science...about a second before the boat touches the water I start the engine, let it idle for about 3 seconds to get some oil pressure and she is ztill backing up...i throw it into reverse and only rev it up to about 1500 rpm and she is watching the mirrors for it to move off the trailer...she stops as soon as it moves, throws it into drive and is heading back up the ramp.
Old Sep 20, 2019 | 09:06 AM
  #29
seventyseven250
It sounds so easy, but it seems like most people make a real rodeo out of it.
Old Sep 20, 2019 | 09:12 AM
  #30
Tom's Avatar
Tom
My lunch routine is a bit more complex, as I'm usually doing it myself. It normally takes me about five or 10 minutes from pulling in to the point where I am ready to pull away from the dock. I always shut the engine off, and at some ramps I pull over to one of the "courtesy docks" so others can use the ramp while I'm parking.
I'll get laughed at in this forum, but 12 miles per gallon towing frustrates me, so every little bit helps!
