Oil Confusion
Old Sep 16, 2019 | 10:58 PM
dougxlt's Avatar
dougxlt
Oil Confusion
New owner of a classic, mint condition1995 F150 XLT / 302 / 5.0 ltr.... One of the first steps was to start out with a new oil change. The owners manual says 10W - 30 for my climate zone. However, dealership, as well as O'Reileys, AutoZone says the new specs from Ford is to use 5W 20. I had it loaded with the latter today, but could not find any supporting information on this subject. Scared to put any miles on her until I hear from you experts. Thanks for an peace of mind you can give me on this subject !
Old Sep 16, 2019 | 11:01 PM
85e150's Avatar
85e150
10w-30 is fine. Use a high mileage vehicle oil if you want.
Old Sep 16, 2019 | 11:33 PM
BS51993's Avatar
BS51993
Stick with 10W-30. It made it 24 years off of that and didn't mess anything up.
Old Sep 16, 2019 | 11:35 PM
dougxlt's Avatar
dougxlt
Thanks, understood. But I've put 5w 20 into the motor per specs that auto stores are telling me that "Ford changed the specs". The engine has 152K. Is this OK, or do I need to flush and go against these new "specs" ? As an addendum, I do not know what the former owner was running in the truck... Could it be FORD decided this is a better option moving forward given the advances in synthetic oils? Thanks Again
Old Sep 17, 2019 | 05:02 AM
sloopdog1's Avatar
sloopdog1
I would use the 10W 30 high mileage oil. The tolerances inside the engine don't get tighter over the years.
Old Sep 17, 2019 | 09:08 AM
Conanski's Avatar
Conanski
That spec applies to new vehicles which are built with much tighter specs than yours was to begin with and was done to improve the fuel milage rating. 5w20 oil will help cold starts during the winter if the temps drop significantly below freezing, if that doesn't happen where you live then a lighter weight oil isn't needed. This oil should not damage your motor but that depends on it's overall condition, listen to it at cold starts and once fully warmed up to see if there are any mechanical noises that weren't there before, if it is noisier change it out.
Old Sep 17, 2019 | 09:16 AM
dougxlt's Avatar
dougxlt
Thanks for the reply from all, and especially Mr. O'Brien. I figure I'll run this for 1K, drain, and then jump back into 10W-30 High Milage. I just needed to know that I was not going to damage the engine in the short term. I'm not sure why FORD issued changes to 1995 302's with providers other than the green folks wanting to "improve" gas milage, and thus running a thinner oil.....? Hmmm. Thanks again to all. Learning as I go....
Old Sep 17, 2019 | 09:47 AM
woodson84's Avatar
woodson84
You haven't had the truck long eh? Trust me, you're going to want it to have better gas mileage too! Or at least your wallet will!
Old Sep 17, 2019 | 10:03 AM
dougxlt's Avatar
dougxlt
Indeed. Not a daily commuter truck though, so low miles. Just a work truck on our mini farm. I'm most concerned with keeping the engine in tip top shape, and the right (correct) oil I reckon is a good place to start !
Old Sep 17, 2019 | 10:27 AM
My4Fordtrucks's Avatar
My4Fordtrucks
I use either 10W-30 or 10W-40 in my 302. Why wait for 1,000 miles and not change it immediately if your worried about it? I would run the 5W-20 until the next time it is due to be changed. Seems like a waste of time and money to do it sooner.
Old Sep 18, 2019 | 10:23 PM
00t444e's Avatar
00t444e
15w40 diesel oil is what I use in older pushrod engines like the 302. 10w30 is the absolute lightest weight oil you should run in that engine, there is no way I would run 5w20 in it, another classic example of why you shouldn't take advice from people at the auto parts stores.
Old Sep 18, 2019 | 11:10 PM
dougxlt's Avatar
dougxlt
Thanks for the reply double ought T triple 4 E ! Diesel 15w40 for older pushrod 302 (152K Miles) ? Would love to hear more of your reasoning for doing this? Not doubting, just learning. That nagging feeling that the "experts" are wrong has forced me to park and collect more info. At the very least, get 10W30 back in her in the next week. Appreciate if you could expound upon 15w40 and why. Thanks Again.
Old Sep 19, 2019 | 02:29 AM
Bruce W.'s Avatar
Bruce W.
I agree totally! I use 15w40 Rotella in summer and 10w30 winter in my 170K mile 460. Running 5w20 would make me nervous.
Old Sep 19, 2019 | 06:38 AM
DBGrif91's Avatar
DBGrif91
Refer to TSB 02-1-9 — this is a direct quote:
”Ford Motor Company now recommends SAE 5W-20 viscosity grade for servicing most gasoline and flexible fueled vehicles.”
The list of applicable vehicles includes your 1995 F150. I’m not saying all parts guys are experts, but this is the kind of info they refer to when they say Ford updated the specs. I know many parts guys that were technicians prior to selling parts and have forgotten more than I know after 18 years combined experience (3 years professional + 15 hobbyist.... I think that’s how math works).
Engine damage due to incorrect oil takes time, generally speaking. 1 or 2 service cycles of the wrong viscosity is unlikely to harm anything as long as the engine is in good mechanical condition to begin with. There’s always exceptions but there’s also usually other factors at play (short drive times or abusive driving habits, for example).
This one service on 5-20 won’t kill the engine - it might actually help clean some of the internal passages.
Old Sep 19, 2019 | 09:43 AM
00t444e's Avatar
00t444e
Ford wants older vehicle's off of the road so you have to buy a new one, what better way to do that then to recommend an oil that will cause the engine to wear out quicker. The basic design of the 302 dates back to the 60s and it was common to run 40 or even 50 weight oil in them back then.
