Will it dent?!?
Old Sep 15, 2019 | 05:26 PM
NStorm's Avatar
NStorm
Will it dent?!?
I do enjoy this guys videos. This is a good one...
Old Sep 15, 2019 | 05:53 PM
Nerfbar11's Avatar
Nerfbar11
Tough stuff!
Awsome video! Ford should use this!
Old Sep 15, 2019 | 06:54 PM
Nathan's Avatar
Nathan
I know some guys with Ram 3500s that have dented their bed sides with their chest while loading things into the bed from the side. Yes, their CHEST!
Nathan
Old Sep 15, 2019 | 07:06 PM
fordman19762003's Avatar
fordman19762003
I knew they would dent the day after I picked mine up. I removed the cover/lock where you stick the rod to lower the spare and set it on top of the bumper. Then I forgot about it and gently lowered the tailgate down and stopped when I felt resistance but I ended up leaving a shallow dent when the lock got pinched in-between the tailgate and bumper.
Old Sep 15, 2019 | 08:21 PM
puddintank's Avatar
puddintank
Here’s another one.
Old Sep 15, 2019 | 11:06 PM
PackerBacker_TX's Avatar
PackerBacker_TX
Everything dents eventually
Let's point out some facts here.
1. It's a TRUCK, not your mom's Navigator. Get to work.
2. Trucks are typically used for WORK and PLAY. Load it up, haul stuff, go off road, etc.
3. I've personally owned 4 trucks. (1 chevy and 3 Fords) - A scratch, scrape, dent, chip, bump are all represented as a badge of honor or a story to tell.
4. I like aluminum because it doesn't rust. 2 of my trucks had steel and rust to go with it. When I resell my truck I want top dollar.
5. When I see the competition doing commercials depicting a front loader dropping a TON of boulders from 8' above the bed of a truck, my next thought is Mr. front loader's gettin his butt kicked. Because NOBODY in their right mind would treat a pickup like that - period. Even a tool box resting on the side and dropping down on the bed on a corner - that's questionable. Are these Men or Monkeys?
Old Sep 16, 2019 | 06:47 AM
bertscw's Avatar
bertscw
I did that with my keys on my brand new 2001 F-350. Left a small round dent that I lived with for 19 years to remind me not to be stupid.
Old Sep 16, 2019 | 09:57 AM
HRTKD's Avatar
HRTKD
I leaned in against the bedside of my long bed and it flexed in. Once I stopped doing that, it flexed back out and didn't leave a mark. I'm a little more careful now.
Old Sep 16, 2019 | 06:19 PM
Louisville Joe's Avatar
Louisville Joe
Actually, this video in a way makes the aluminum box look bad. Sure, hitting it with blunt objects might not leave a dent, but they are replacing the whole box on that truck for relatively little damage! I wonder if the accident would have caused the same amount of damage to a 2016 Super Duty, and if it did I wonder if the repair would require replacing the whole box. Seriously, my friend had similar accident with his 2013 GMC Sierra HD and the body shop simply replaced the quarter panel and tail light.
Old Sep 16, 2019 | 09:58 PM
AMXDREAMER's Avatar
AMXDREAMER
They dent with hail, I learned that in the first 2 months of ownership....
Attachment 281324
Old Sep 16, 2019 | 10:03 PM
HRTKD's Avatar
HRTKD
Looks like the Measles.
Mine has been through a few hail storms, but apparently not severe ones.
Old Sep 17, 2019 | 04:26 AM
slownsy's Avatar
slownsy
And you have never seen a steel vehicle dented by hail, I have seen several and they did not have to use textures to see the dents.
Frank.
Old Sep 17, 2019 | 09:38 AM
Ls1itldo's Avatar
Ls1itldo
Did the exact same thing, was able to use DIY paintless dent repair to remove 95% of it, but I know it is there...
Old Sep 17, 2019 | 10:38 AM
ForCal's Avatar
ForCal
In many cases the bed side would be replaced, I wonder if that's no longer cost effective. Some of those first hits he did with the side of his fist, would have surely dented my Toyota. I've dinged it in the garage by accidentally bumping it with my elbow.
Old Sep 17, 2019 | 08:45 PM
unit's Avatar
unit
That was the bed side -I think they are built of heavier aluminum than the rest of the body. I wonder what a hard blow with a fist would do to a door or front fender. The aluminum on the doors and front fenders don't seem to be as durable to me.
HILLBILLY BOB
Aug 27, 2018 06:09 AM
Mr. Bob
May 30, 2007 10:18 PM
