F600 help
Old Sep 13, 2019 | 07:50 PM
Johnset's Avatar
Johnset
F600 help
I have a 1969 f600 Ford truck I need a new steering gear box was told I could use one out of a 3/4 or 1 ton pickup does anybody know if this is true or not. If anyone can help me it would be greatly appreciated
Old Sep 13, 2019 | 08:55 PM
RichS2659's Avatar
RichS2659
It is totally different as the gearbox shaft goes out through the frame for your F-600. You can get one from NAPA, or other stores. Or you can get a power steering gear from a later model.
Old Sep 13, 2019 | 09:06 PM
Johnset's Avatar
Johnset
Thanks for the info hadn't considered switching over to power steering maybe I'll look into it thank you very much
Old Sep 13, 2019 | 10:48 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Johnset
I have a 1969 F600. I need a new steering gear box, was told I could use one out of a 3/4 or 1 ton pickup.
Does anybody know if this is true or not. False!
There is no way, NONE that an F100/250/350 steering gear box would work in an F500/750, as the boxes are completely different.
C9TZ-3504-B (replaced C7TZ-3504-B) .. Manual Steering Gear Box / Obsolete
1967/70 F500/750 & 1971/72 F500/750 2WD with 5,000, 5,500, 6,000 & 7,000 lbs. capacity front axles.
No Ford dealer or obsolete parts vendor has any. Contact redheadsteeringgears.com in Seattle WA for a rebuilt.
Swapping in P/S will be a major undertaking, as most of the parts are obsolete. Where will you find them?
Old Sep 13, 2019 | 10:57 PM
Johnset's Avatar
Johnset
Thanks for the info and thanks for the tip on the website I'll check it out
Old Sep 13, 2019 | 11:00 PM
Johnset's Avatar
Johnset
Quick update that website does not offer anything above a F-450 thanks anyway
Old Sep 13, 2019 | 11:01 PM
NumberDummy
Website doesn't offer anything larger than an F450
Call Red Head and ask. I know some other members with F500/750's have had their boxes rebuilt there.
Also, ask questions in the LARGE TRUCK forum, most members of this 1967/72 forum have pickups.
treetrunks
Mar 25, 2010 07:20 PM
John Austin
Jun 8, 2005 07:21 PM
scoobzter
Apr 29, 2003 05:27 PM
joe66
Nov 2, 2001 09:28 PM
