Sponsored by: Real Truck
Level kit rough ride
Old Sep 13, 2019 | 06:28 PM
Frisbeekev's Avatar
Frisbeekev
I recently had a rough country 2in level blocks and larger rims and tire 296/65/20 installed on my 2016 f250. The ride to me seems to be rougher, almost like I can feel every bump in the road, even the slightest ones. Granted it is a 3/4 ton truck, with a light rear end so some bouncing is expected but it seems more than usual. Is this is a common trait of level blocks, do my tires need a better balance job, or is it something else?
Old Sep 13, 2019 | 08:13 PM
moymurfs's Avatar
moymurfs
If you dropped in sidewall height (probably stiffer as well) you now have less tire absorbing bumps. That contributes to the ride quality.
Old Sep 14, 2019 | 06:27 AM
Deuce40s's Avatar
Deuce40s
Sounds like you need new shocks. The OEM shocks are probably at the end of their lifespan, maybe the extra 2" is enough to make it noticeable.
Old Sep 14, 2019 | 06:31 AM
2011350diesel's Avatar
2011350diesel
I'had 3 half tons and alway put the leveling blocks in front. It never softened the ride, that's for sure.
In my 350 I used the springs and had to get new shocks anyway.Went with the Bilstiens. The sprint def. ride better than the blocks.
ommegang
2009 - 2014 F150
24
Mar 7, 2014 02:39 PM
Dorito
Feb 9, 2012 08:05 PM
Shmuck
2004 - 2008 F150
Feb 5, 2009 12:55 PM
sean23johnson
Oct 21, 2006 11:50 AM
Scotter06
Sep 6, 2006 09:13 PM
