Winch options
Old Sep 12, 2019 | 08:54 PM
Bohen's Avatar
Bohen
Winch options
Soooooo my RH Legend front bumper has a 2 inch receiver so my only option is a receiver mount for it and run leads to the back if need be . What is the ideal pull weight for the rear tow hitch ? I know front receiver is rated at 9500 lbs , my truck with a full tank and me is 9300 lbs .😕 Also if pulling from upfront how do I strengthen the receiver so if there is a slight angle it wont rip off . I dont plan to get stuck but better to have and not need plus it someone is stuck I'd like to help them . Winter is coming and these people out here suck at driving .Thank you
Old Sep 12, 2019 | 09:26 PM
speakerfritz's Avatar
speakerfritz
When I do super heavy on my front bumper hitch I wrap a thick chain around the hitch and hook terminate each end to the tow hooks.
Old Sep 14, 2019 | 11:04 AM
Bohen's Avatar
Bohen
What do you think the Max you can pull with it in the 2" receiver and a thick chain wrapped around it and to the tow hooks as you have said ? Also what is your winch setup if you dont mind , I'd like to get a really nice one but I just can't wrap my head around spending a $1000 for a wench there were only used a couple times I got a really good buddy who has a Smitty and Another one who has a HF 12000 . Both of them have not had any issues with them
Old Sep 14, 2019 | 01:59 PM
speakerfritz
My chain wrapping excursive is for when I back in my 10k trailer into parking spots which is a lot easier than trying to use the rear hitch. My thinking is the chain wrap across the hooks will give me more tongue weight .i don’t think the chain wrap adds anything to the straight line pull.
my front hitch is a 9k straight line pull and 500lb young weight.
i wouldn’t be a freight to put ac12k winch on my front witch because there are loop back devices that you can use to terminate the cable to one of your hooks which in theory would give you 2:1 instead of 1:1, increasing your which power while decreasing your winch load since the tow hook would get part of the load (50% if cable length from hook to load and winch to load was the same, etc)
Old Sep 15, 2019 | 02:38 PM
jav_eee's Avatar
jav_eee
I have a smittybuilt and used to have a harbor freight. Both worked when I needed them to.
Old Sep 15, 2019 | 10:09 PM
UP_There's Avatar
UP_There
I've had a few brands of winches over the years. Harbor Freight will fail you. Smittybuilt are decent, but Warn is hands down the BEST. Best warranty, best performance, best support as well. I run a 12k on a winch bumper for the front. Bumper is bolted directly to the frame, and if you use a ****** block, you can exceed basically anything you ever dreamed of pulling out.
Old Sep 16, 2019 | 08:23 PM
senix's Avatar
senix
smitty built bumper with a warn winch here too. Get the warn.
Old Sep 16, 2019 | 09:03 PM
HRTKD's Avatar
HRTKD
After experiencing the same problem with two different Mile Marker winches, I would not go with that brand. Warn gets my vote.
On my Titan I had a Mile Marker winch mount rated for 9500 lbs (same as the winch). I did one off angle recovery that was almost 90°. It wasn't at the limit of the winch/mount though. Maybe 60%.
Old Sep 17, 2019 | 07:30 AM
jav_eee's Avatar
jav_eee
When I was younger I used to drool over the MM hydraulic winches. Thanks for reigniting those feelings haha
Old Sep 17, 2019 | 09:35 AM
HRTKD's Avatar
HRTKD
Last I looked, they still have them. They're run off of the power steering pump.
Old Sep 17, 2019 | 11:21 AM
smoky_diesel's Avatar
smoky_diesel
I made a custom 1/4" plate winch mount I don't need anymore. Where are you located OP?
I testes the HF12000 and posted result here on this site. It's really more like a 9k or so.
https://www.ford-trucks.com/forums/1...h-install.html
Old Sep 17, 2019 | 08:24 PM
Bohen's Avatar
Bohen
Vancouver Washington
Old Sep 17, 2019 | 08:47 PM
Bohen's Avatar
Bohen
Can the high idle mod be used on a tuned truck?
Old Sep 18, 2019 | 03:13 PM
smoky_diesel
your pm box is full
Old Sep 18, 2019 | 04:47 PM
Bohen's Avatar
Bohen
your pm box is full
Empty now 👍
