Computer Chips & Tuners
87 octane performace chips?
Old Oct 7, 2003 | 09:28 PM
WXboy's Avatar
WXboy
Question 87 octane performace chips?
Is there a chip that I can run 87 octane with, but still have reprogrammed shift points and no speed limiter?
Old Oct 7, 2003 | 09:59 PM
FTE Ken's Avatar
FTE Ken
Yes, a Diablo chip can be programmed for that.
Old Oct 8, 2003 | 04:13 PM
WXboy's Avatar
WXboy
Are those the chips that FTE sells? Can I look up the prices on here somewhere?
Old Oct 8, 2003 | 07:09 PM
FTE Ken's Avatar
FTE Ken
Motorhave sells them here:
http://www.motorhaven.com/customer/p...&cat=37&page=1
and here:
Old Oct 8, 2003 | 10:02 PM
WXboy's Avatar
WXboy
So on that one chip, I can have it programmed with an 87 octane program ONLY? Am I reading that right? Because the multi-program chip would be over $300 and that is nuts. If I'm reading correctly on the first chip, a single 87 octane program is all I'd want anyway.
Thanks in advance!
Old Oct 8, 2003 | 10:12 PM
FTE Ken's Avatar
FTE Ken
Yes, you can get an 87 octane only program without having to get a multi-position chip.
Old Oct 9, 2003 | 11:23 AM
WXboy's Avatar
WXboy
OK thanks!
Old Oct 16, 2003 | 11:44 AM
TOWB19's Avatar
TOWB19
I am a newbee and this is somewhat confusing.
1) What is the stock program? Is it different than the factory "stock" program.
2) Isn't the stock program for 87 octane?
3) What program is recommended for towing with 87 octane?
4) What program is recommended for towing with 91 octane?
5) I rarely see 93 octane in California so should I order the chip for 91 octane instead of 93 octane?
Thanks in advance for any help.
Old Oct 16, 2003 | 02:56 PM
CPerry's Avatar
CPerry
TOWB19, what truck, engine and trannt do you own?
Old Oct 16, 2003 | 04:15 PM
TOWB19's Avatar
TOWB19
I have a 1996 Explorer with a 4.0L V-6 and a 4 speed automatic transmission (160 horsepower).
I recently purchased a 19 ft. trailer (3,500 lbs.) and even though I am well within the rated tow capacity (5,000 lbs.) I feel that I could use some extra performance (horsepower) especially when towing up California hills and mountains.
Old Oct 22, 2003 | 12:03 AM
FTE Ken's Avatar
FTE Ken
[QUOTE]Originally posted by TOWB19
[B]I am a newbee and this is somewhat confusing.
Its what's in the vehicle now.
Anything you do now, doesn't change with the stock setting on the chip.
I don't recommend an 87 octane program. It will only reprogram the shift firmness and shift points with minimal power gain. You need a premium fuel performance tune to get a gain for towing.
Not sure what you mean? We target 91 octane by default when programming a performance tune for California.
See above.
Old Oct 29, 2003 | 10:59 AM
TOWB19's Avatar
TOWB19
Thanks for responding to my previous questions.
I still have one question which is similar to the one posted by WXboy so I think that I am not alone in being confused by this issue.
In you reply you state "I don't recommend an 87 octane program".
Does that mean that if I purchase a chip for towing running 91 octane, you don't recommend that I purchase it with the 87 octane program which I would run when I was not towing and not using premium fuel?
Old Oct 29, 2003 | 11:25 AM
FTE Ken's Avatar
FTE Ken
I don't recommend an 87 octane only chip. The only major benefit will be the transmission. If you get a 3 stage chip (stock/87/premium) because your driving needs change then it would make sense to get it.
Buck 1
2009 - 2014 F150
19
Jun 2, 2014 02:21 PM
FordRacing85
3.8 & 4.2L V6
Nov 17, 2004 08:30 AM
Nightrain
Jul 10, 2004 09:39 AM
ForDen
May 2, 2004 07:11 PM
2000sport
Aug 6, 2002 10:19 PM
