Scraping noise behind dash after accelerating
Old Sep 11, 2019 | 06:27 PM
therealjohn's Avatar
therealjohn
2005 SuperCrew Lariat 5.4
When I accelerate from a stop, I hear a scraping sound behind the dash for a few seconds.
Imagine what it would sound like if your keys scraped along the hard plastic as they swung back an forth. That’s kind of what it sounds like, only inside the dash, low - like behind the steering wheel.
(It’s not the keys...)
happens when AC is on or off. Doesn’t seem related to the HVAC.
Any clues what what that might be?
Old Sep 11, 2019 | 08:51 PM
pdqford's Avatar
pdqford
Could it be the sound of coolant being pushed into the heater core and an air pocket being pushed out?
Old Sep 11, 2019 | 09:37 PM
therealjohn
Hm, no idea. Would that still make sense to only hear that on acceleration?
I did recently get a coolant flush, and I can’t recall if it’s new since then or not. But it happens every time I accelerate.
Any my way to test that theory and eliminate air in the coolant lines?
Old Sep 11, 2019 | 10:15 PM
Onemoreblessedtexan's Avatar
Onemoreblessedtexan
Old Sep 12, 2019 | 10:12 AM
Rumble phish's Avatar
Rumble phish
I think this is spot on. You hear it when accelerating because the coolant is flowing back into the heater core. Same thing happened to my '97, except it was due to a small leak in the passenger side head gasket that let air into the coolant system when the truck was cooling down after being run up to operating temp. It never once overheated, but it sounded like someone was pouring a big pitcher of water when I accelerated. Could easily be mistaken for a scraping sound.
Old Sep 18, 2019 | 04:07 PM
1saxman's Avatar
1saxman
Note the hot coolant level in the surge tank and compare it to the cold level the next morning. If the hot fluid is expanding and the cold fluid is being drawn back into the engine by vacuum, the system is tight and air pockets will work their way out over time.
If this is not happening, the system is open and will have air in it. Since somebody messed with the cooling system recently, I'd say that's the most likely source of the problem. If you have low coolant, it will eventually all go into the engine from the surge tank so keep it up to the 'cold level' by adding fluid of the same type mixed with distilled water.
Maybe its just a loose clamp. If you have any replacement screw clamps I can guarantee you at least one is loose - there is no substitute for the factory spring clamp.
mkain
Oct 3, 2011 02:31 PM
parameduc100
Apr 13, 2011 11:02 PM
HighOctane
Sep 20, 2007 02:13 PM
