I have a 73 manual brake standard trans front disc, I am upgrading to power. I have a complete standard trans pedal cradle with brake pedal marked D7TA-LA. So I will be using 77-79 Power booster and master. My question is would it be easier to swap just the pedal or the whole cradle? I have searched and saw a couple have asked this but couldnt find an answer, Thanks, Mike
I have searched and saw a couple have asked this but couldn't find an answer. Thanks, Mike
D7TZ-2455-B .. Power Disc Brake Pedal-Use without Speed Control / Marked: D7TA-LA or D7TA-2455-LA / Obsolete
1977 F100/150/250/350 with Manual Transmission // 1978 F100/150/250/350 & Bronco // 1979 F100/150/250/350 & Bronco before serial number DJ0,001.
I updated my manual brakes to power in my '73 F-100 with a 360/C6 to power. I found a '73-'79 truck in the salvage yard that had a good booster and it had a bracket that offset the booster higher on the firewall. I disconnected the rod from the pedal and took everything from that rod to the booster including the plastic fitting that the vacuum hose that snaps into the front of the booster. I had to replace the M/C (O'Reilly's) anyway as the reservoir go dry. I cleaned up the firewall brackets and painted them and scotchbrighted the booster and shot it matte black, bought a new vacuum line and installed and it works great.
