2001 Ford Excursion 4x4 ABS module power source
Old Sep 10, 2019 | 09:24 PM
aero993's Avatar
aero993
Question 2001 Ford Excursion 4x4 ABS module power source
Hello,
Trying to start the trouble shooting process of OD flashing and no speedometer. I want to male sure the installer didn't cut/splice the power wire to the ABS module.
So exactly what color is the wire and where is it located?
TIA
Old Sep 11, 2019 | 05:28 AM
01__Excursion's Avatar
01__Excursion
Here are a couple pages from the book..
File Type: pdf
File Type: pdf
Old Sep 11, 2019 | 12:35 PM
aero993's Avatar
aero993
thanks for your help
Old Sep 16, 2019 | 10:25 PM
aero993's Avatar
aero993
01__Excursion
Quick question, do you know what the location and the color of the wire the could be causing the problem? I want to make sure that the installer didn't tap into the wrong wire. Also,do you know which fuse to check?
Old Sep 17, 2019 | 05:50 AM
01__Excursion
I don't have any first hand experience with your situation, you'll probably need to check all of his connections and the wires he tapped into.
I can scan more pages of the ladder diagram for you to follow the trail.
Wbrann51
Dec 15, 2018 06:18 PM
Bowie
20
Aug 12, 2009 07:22 PM
ckb2steelers
Modular V10 (6.8l)
Aug 31, 2006 04:53 PM
