Dash lighs ?
Old Sep 10, 2019 | 09:54 AM
460me's Avatar
460me
Dash lighs ?
When i turn on the parking light or head lights everything works even the selector light on the column but the dash lights won't turn on,Only when I push the brake pedal the dash lights come on,it will do this with the head light switch off. Something is going on.
Old Sep 10, 2019 | 10:06 AM
73GreenBean's Avatar
73GreenBean
I'd check your wires under the dash for starters. Sounds like you may have a short and the wires are rubbing against the brake pedal assembly causing a grounding effect. When you push the brake pedal the wires are no longer grounding and thus the dash lights come on. Most dash lights in the original harness are a light blue with red stripe wire if I remember correctly
Old Sep 10, 2019 | 06:02 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
X2 and you better find it before you have a fire and a melted mess of wires up under there. Look in the movement/swing area the break pedal.
Old Sep 10, 2019 | 09:51 PM
460me's Avatar
460me
Thanks I will take a look
PapaGeek
General Automotive Discussion
Jul 2, 2016 06:14 AM
wr310rdr
Jun 24, 2013 04:13 AM
ASoCalCowBoy
Nov 12, 2006 10:13 PM
ddavidv
Dec 1, 2003 09:07 PM
