Help!! Dreaded Dorman 42025 insert found
Old May 30, 2022 | 02:15 PM
Krashbear's Avatar
Krashbear
2nd Gear
I get nervous about applying heat in that area of the engine. I had seen where you were considering putting the Dorman back in with extra threadlock. Which is what caught my attention. I figured if you did that you would have had to get it out to get the CalVan insert in. Your experience in getting that out would be helpful, unless you didn't put the Dorman back in.
Old May 30, 2022 | 07:47 PM
Glblwrmer's Avatar
Glblwrmer
I didn't put the Dorman back in. I drilled the cylinder and JB Welded the Cal Van insert in.
wbubble
Modular V10 (6.8l)
92
Jun 28, 2019 03:34 PM
msugeek
2004 - 2008 F150
May 11, 2019 02:25 PM
posF250SD
Apr 18, 2015 06:13 PM
ggalleone
Modular V10 (6.8l)
Jun 12, 2011 04:52 PM
KentuckyCountryBoy
Mar 5, 2008 09:00 PM
