Hey all, looking for some advice and input. I bought a 2011 F350 6.7 about 5 months ago. When I bought it it was fully deleted with a straight pipe but here in CO we have emissions so the dealership I bought it from had to put all the emissions stuff back on. I asked for receipts but they were really shady about it.
Labor Day I'm driving home from camping and the truck just stops running. It'll start and idle for about 5 seconds but dies after that or the moment I put it under load. I've checked fuel filter and fuel flow and everything seems fine. I'm beginning to wonder if the dealership f'ed me and put a used up DPF in there to try and save money? I don't get a DPF or DEF warning b/c I'm sure they never reversed the delete codes from the original delete.
Its at the mechanics tomorrow but I'm wondering, if it is the DPF, is it worth spending the money getting a new DPF or should I just save 50% and buy another delete kit? I have a little less than 2 years until the next emissions so I have some time to figure it out.
Anyone else have any other ideas on what could have killed it besides the DPF? Super confused. Thanks in advance!
Reason: Misspelling
slorider, there was no check engine light so I didn't even try, I'm not sure the code reader I have access to would pull the hidden codes but I should have tried.
How many miles in those five months? The first thing is to have the techs troubleshoot if it is or isn't the DPF. It could be anything, especially without a DTC. There can be DTCs that don't necessarily trigger a CEL.
Do you know if the dealer put stock Ford calibration back on the ECM? Or did they just hook up the DPF so they could visually call it "good?" If they just bolted it up and the truck still has a tune, that DPF has been slowly filling with soot since it hasn't been commanding active regeneration. I would have never thought about this but the shop that works on my truck was telling me a story where one of their customers purchased a "stock" F350 with the DPF installed but it turned out it was previously tuned and resold with the DPF put back on. Broke down while they were towing their horses.
If you have driven thousands of miles then it has been commanding regeneration otherwise you would have broken down in 500-1000 miles or so.
I've put around 5k on the truck since I bought it. Since I'm not getting any warning lights, and knowing they were trying to do this all on the cheap, I'm assuming the shop did not reinstall the original code and just hooked up enough to pass basic emissions. I know they didn't re-connect the DEF system and I'm not getting a warning on that either. And I've seen the prices on a new DPF, it's through the roof! I may just go back to the delete kit if that's the case, I'd really just need the straight pipes again.
At the mechanic today so I'll update once I hear from them.
If you asked for receipts, and they seemed shady about it...…...I don't understand why in the world you would have ever bought that particular truck from that dealer????? Definitely crooks!
I'd already unfortunately purchased the truck when it came to that. I had two months before emissions were required and I'd planned another work around but when that failed I took it back to them as CO law requires dealerships to sell emissions passing vehicles. After they beat around the bush on invoices for the parts installed I knew they just went the cheapest route and wouldn't lift a finger to help with anything else.
I agree with @kper05. If they just reinstalled the hard parts for the emissions and didn't reflash the ECM with the factory emission tune, your DPF is probably clogged. There'd be no check engine lights for emission related components because they are disabled in a delete tune.
I would advise you not to drive that truck another mile. If you have a deleted truck with the DPF still on the vehicle (it appears the dealer installed the hard parts but did not flash the ECM back to stock) then you are causing back pressure that will take out the engine. Problem is now you have to prove the ECM is not stock so the dealer has to fix it.
Yeah, I don't know how to confirm (prove) stock calibration or not. Maybe check and see if the EGT11 and EGT14 are showing crazy temps at idle? Mine isn't stock but nothing is different on the dash or my basic XLT two line display. Towing it to another dealer, paying a quick diag fee to see what they say (they'll be able to connect IDS and figure it out) and then going after the selling dealer is one way. But then you may have another tow fee to get it to the selling dealer to fix. This starts getting expensive.
If DPF on with no emissions calibration is the issue, I am impressed you made it 5,000 miles! At this point, the DPF might need replacing. I would have them fix everything and confirm there isn't engine damage.
Does Colorado actually test and check if the emissions equipment is there? Last I heard it was just an opacity test, and a tuned truck with straight pipe exhaust would pass that so long as you weren't running on a really aggressive tune. I'm just stating what I know they do in some areas, I'm sure the liberalism is spreading and their testing is going to get more strict as time goes on.
If you drove 5k miles like this then I doubt it would be the dpf. I would be looking at the hpfp. They will quit on you while running. If you do suspect the dpf just unbolt the exhaust pipe and see if the truck will run. I think you have other issues. Please keep us updated.
Finally got an update from my mechanic on Friday, when they finally got around to pulling the exhaust, after looking at a few other suspected items they wanted to check off, they found that both the CAT and the DPF were plugged up with soot and causing the engine to not be able to breath. Come to find out that the dealership I bought the truck from didn't fully return the truck to emissions standards, they just slapped a CAT and DPF on there and let me run with it, so no regen cycle, no DEF helping with the soot, nothing other than highway speeds to clean out the DPF.
After reviewing the options from the mechanic I just decided that I'm going to go back to straight pipes for the time being as getting the DPF cleaned and repaired and then reflashing the ECM and everything else was going to cost way too much. I'm also exploring options with the dealership. CO law states that a dealership cannot sell a vehicle that does not meet emissions standards. While this dealership got the truck to pass emissions it technically wasn't "brought to emissions standards" so I need to chat with them first and see if they'll step up and fix it properly or if I'll need to pursue legal actions. Good times.
That sux when there's a dealer who will bone a person to make a fast buck. But it's that kind of world for sure. Good luck in your endeavours and with the truck. Let us know how you make out with your ride.
