SCJ piston options
Old Sep 8, 2019 | 02:38 PM
77custom408's Avatar
77custom408
SCJ piston options
I’m gathering parts for my 79 Bronco and I picked up a 460 D1VE block and new Eagle cast 4.14 crank for $150 yesterday, I’m gonna use Eagle 6.7 rods and Ford Racing SCJ heads that I already have. I’m having trouble locating pistons for a 501ci build using these heads, if anyone knows where I can find pistons I would greatly appreciate it. Thanks
Old Sep 8, 2019 | 11:44 PM
85e150's Avatar
85e150
You probably need a custom piston with that stroke and rod.
All 460 all the time here:
https://www.460ford.com/forum/40-eng...1-24-09-a.html
And a thread specific to your issue. It's a bit old but there are piston supplier suggestions as well:
https://www.460ford.com/forum/37-eng...-bad-ugly.html
Old Sep 9, 2019 | 08:44 AM
77custom408
Thanks I did find one that Mahle makes but damn they are pricy, I might just get a Scat 4.300 crank and rods and use JE pistons, I got that Eagle crank for free so no big loss if I don’t use it
Old Oct 31, 2019 | 11:52 PM
Mitch Huested's Avatar
Mitch Huested
Scat cranks are, by all acounts, stronger than the Eagles anyway. Wiseco makes a good forged piston for the 4.3 crank/6.7 rod combination as well. Recommend Total seal rings, if you have the time to fit them.
BigBlocker0248
Jan 17, 2016 03:20 PM
78LEROY
Jul 1, 2010 04:34 AM
r_reed
Oct 6, 2008 09:15 PM
gyger1
Apr 25, 2006 07:21 AM
kevinupchurch
May 17, 2005 10:24 PM
