6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Transmission Flush
Old Sep 7, 2019 | 04:06 PM
Rudiak's Avatar
Rudiak
Transmission Flush
I have a 2008 F250 6.4 4x4 and had the transmission flushed/filled by dealer at 90k. I do not have the external filter and the internal filter was not changed they said it was lifetime. The transmission has been flawless. The truck now has 185k. Should I get another flush/fill done? Your knowledge, experience, and opinions are welcome. Thanks!
Old Sep 7, 2019 | 08:24 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The dealer is wrong. The filter in that trans is NOT lifetime. You should change the fluid and the filter.
Old Sep 9, 2019 | 04:00 PM
Rudiak's Avatar
Rudiak
Mark K I read a previous post of yours from 2014 where you said the filter is lifetime. Same thing my Ford SA said at around the same time. What gives?
Old Sep 9, 2019 | 08:19 PM
Mark Kovalsky
Before 2008 the filter was lifetime. Sometime after 2008 production started the internal filter was changed to a greatly improved filter. That filter has a regular change interval. If your truck does not have the external filter you have the improved filter and it needs to be changed.
jle70
18
Jun 5, 2017 08:25 PM
69ford99
2004 - 2008 F150
Sep 5, 2009 09:47 PM
MY1STCREW
2004 - 2008 F150
46
Feb 20, 2009 12:50 AM
don766
2004 - 2008 F150
Sep 18, 2008 05:14 PM
chixdigit
Feb 5, 2007 11:26 PM
