I have a 2000 7.3 Excursion will a little over 350,000 miles. It is completely stock. I want to make it as reliable as possible since it is getting up there in miles, but also adding a little power back to it. What would be the best upgrades/mods for reliability and also for a little more power?
every oring in the fuel-oil system, its an extensive list
injectors ( at least shim them )
cac boots
ucvh
passenger side head fuel line
hpop
injectors
engine wire harness
turbo
uppipes
water pump
idler pulley
clutch fan
ac air gap
serp belt
radiator
all 5 radiator hoses
