ID differential
Old Sep 5, 2019 | 09:01 PM
sr139fox's Avatar
sr139fox
ID differential
I have a 2001 Sport Trac, 215,000 miles. I plan on changing the rear end fluid. Do I have to look for a tag on the rear end, or can I use the VIN number to figure out what read-end I have? Need to know because if limited slip, i will need the friction modifier. I think 2 quarts should be enough.
It has been a long time since I was on this forum and miss the dedicated Sport Trac Forum.
Dave
Old Sep 6, 2019 | 06:22 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
I think it's on the door tag.
And . . . you could:
1. Block both front tires front and back
2. Lift a rear wheel
3. Put it in Neutral
4. Spin the lifted wheel
If it spins a lot then it's open, if it spins a little then resists then it's limited slip.
Exit 295
Jan 6, 2013 07:42 PM
02GrayPowerStroke
Dec 27, 2007 11:35 PM
Battman76
Feb 6, 2007 08:44 PM
1explorer
Jun 12, 2002 06:10 AM
