Modular V10 (6.8l)
help with settings
Old Oct 7, 2003 | 04:24 PM
SouthBay420's Avatar
SouthBay420
help with settings
wanted to see if anyone can provide some info in regards to setting shift points and pressure for the 1715 tuner. i just got it last week. apparently there was some delay for the 2003 v10. i called Superchips before i ordered it and they told me that it came out last tuesday for the 2003 v-10. when i put the program in, i honestly didnt notice much difference at all. i was a little disappointed. i have 36" pj's ,4:30 gears,FIPK, Flowmaster 40 if that makes any difference. is it better to use the superchips preset program or custom adjust it? thanks for any help you can give me.
Old Oct 9, 2003 | 07:02 PM
jaxf250's Avatar
jaxf250
When I updated the EEPROM in my 2001 with the SCMT, I used the "default" upgrade settings, and man, made a huge noticeable difference. If you don't notice anything at all, I would say call Superchips and ask to talk to a tech. guy. Maybe they have some different chips in the 2003 truck that the programmer did not account for (and thus your's show no diff. in performance). Just a SWAG. Good luck.
Old Oct 11, 2003 | 06:24 AM
V10KLZZ71S's Avatar
V10KLZZ71S
I went with the custom settings.Max shift pressure,raised shift points, removed speed limiter.You probaly wont be able to go higher than 2 marks above stock shift points because you will run into the rev limiter.
