Worn Rod Journal
Old Sep 4, 2019 | 09:48 AM
Camdo's Avatar
Camdo
Option 1 it is. I put it all back together and put the pan on. Its ready to go. I decided to paint the chipper now that the engine is out of it, so it will be a while before engine results are known. I will post back on how it runs. Thanks for all the advice guys. It has given me some confidence. Weather it works or not, I think it is the best choice at this time.
Old Sep 4, 2019 | 09:55 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
I once re-bearing'd a Triumph TR7 4-cylinder - the lower-end in those things were built like the proverbial brick outhouse Forged everything, crank, rods and pistons.
Without using plastigauge, I put a dial-indicator on the rod cap while the piston was at BTDC and moved the rod up and down to get an idea of the clearance. Was way over factory spec, probably 2 or 3 times as much as yours are. That dang thing ran right up to 7K RPM for over a year before I pulled it to put a total-rebuild in it's place.
When I took it apart out of curiosity, it looked like the day I put it together, and that cheesy clearance check with the dial indicator still showed the same clearances... I was running 20W50 and had shimmed the oil pump pressure relief valve so the pressure was on the high side at around 80lbs at cold idle though
Old Sep 4, 2019 | 11:04 AM
Camdo's Avatar
Camdo
Thanks for that story Krewat. I reassembled with a high volume oil pump but did not change the pressure relief settings. Got it from RockAuto. I like the 20w-50w oil, and rocker shaft orifice ideas.
I wish there was some test data on clearances vs oil viscosity vs bearing life. I am sure engineers have done extensive testing on this subject. The recommended allowable clearances in the engine specifications are surely the result of tests. The high side allowable must be the point where the bearing will deteriorate with use but the rate is unstated. Adding more oil pressure and viscosity should stabilize the additional clearance so long as the other bearings can survive the new conditions. Without test data we are guessing. Your experience is an excellent example of viscosity, pressure and clearance. If only there was a chart showing the extended relationship.
Old Sep 4, 2019 | 11:11 AM
krewat's Avatar
krewat
I think another thing that determines how much oil stays on the bearing is rod big-end end-play. The more room around the sides of the rod, the more oil will exit the gap. But maybe I'm overanalyzing at this point
v8only
16
Aug 1, 2010 11:27 PM
beutlej
Modular V8 (4.6L, 5.4L)
20
Aug 29, 2008 10:53 AM
madclone
Bronco II
Oct 17, 2005 12:27 AM
boss429
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Dec 17, 2003 01:21 AM
KJKozak2
Aug 5, 2003 02:47 PM
