One of the extra parts that came with my head purchase, was a new Comp Cams camshaft. The number on it is a core number 37-000-5. Then there are two lobe numbers 5400 and 5441, which is a .206 @ .050 and 212@.050 duration.Lobe lift is .288 and .298 respectively. . . so to me, not a very aggressive cam. But I am not very experienced in Y-Blocks. How does this profile work in a Y-Block? And one else have this cam? Was it a manufacture to buyer request type of thing, since it is listed as a core and lobe profiles, rather than a cam that is sold normally with typical write up, etc.
Definitely mild. was wondering if worth the trouble? Definitely more duration and lift than stock. All Y all the time?? That doesn't mean anything to me . .a page?
Y Blocks Forever is a website that deals with Y-blocks exclusively. I remember reading something there about defective Comp Cam Y-block cam grinds recently, so I looked it up to be sure:
"Last year I had a custom Comp Cam given to me for the EMC engine as a sponsorship, but we could not use the cam due to trying to advance it as suggested. The lobes were all over the place in the 2* and 4* advanced position, causing us to go back to the Isky. I recently had this confirmed when another brand of camshaft was custom ground for our EMC entry for this year, and straight up, it was Ok, but when we went to advance it, one bank was retarded, and the other was advanced, making it unusable. I sent the camshaft back, and it was put on the Cam Doctor machine and confirmed that it had been ground wrong according to the industry standard information. After obtaining the correct specifications for lifter bore angles, the camshaft has been reground and parkerized, and in on its way back to us for dyno testing. Anything other than stock Ford or Iskenderian camshafts should be degreed if you are serious about performance gains without valve to piston, valve to cylinder wall, interference issues or degraded performance."
That is a very mild cam so I would not recommend it because you should be able to go a little bigger without sacrificing anything at all.
For a very tame idle, a regrind of the '57 cam or something like an isky E4 would be good. From there, it just boils down to the compromise of sound and driveability that you want.
A Y-Block behaves the same as any other 4 stroke pushrod engine so if you're familiar with anything else of similar displacement, then the results of a given cam profile will be about the same.
It came with the parts I bought, so its a free-bee.
Comp is a cam that I would avoid like the plague...…. a "McDonald's" type company/atmosphere with more cam related failures than I have ever seen or even heard of by any of the "family" owned cam companies.....and I mean some really ugly failures...… actually, I shouldn't refer to them as a MD company as MD has a lot of quality control whereas IMHO, Comp is just throwing their products out the door as fast as they can...… heck, what do you expect from the prez who is an attorney by trade (: !
I have used Comp Cams in many of my builds. I was just unfamiliar with this cam, this Y-Block process. Have built lots of engines and comp cams are in them.
Originally Posted by PetesPonies
That's the same core, but not the lobe profile. That is much more aggressive than what I have.
You are correct, my bad.
I GOOGLED the CORE NUMBER and I did not notice the PN differences.
I would contact COMP CAM TECH (1-800-999-0853) and see if they can explain what is going on. If for some reason it is not something you can use, I would conact ISKY for a FYB.
I may throw it in. Duration is 14-20 degrees more. Even lift is .026 to .041 more. Should be a great truck camshaft. Like you, I could find the core number and had to dig through some information to see that they had lobe profiles by numbers. But didn't find that complete cam listed anywhere for sale. That is why I thought it is done custom . . pick the lobe profile you wanted. I did a 5.0 engine for a customer once that didn't want an aggressive cam. I chose a 204/214 @ .050 and .484 lift that really made a responsive engine. He was happy. This duration is very close to that . . . I wish the lift was
I'm glad you have not had any issues...perhaps you have been using the 8620 cam cores which have a copper colored base to it. If it looks like a standard silver / metal camshaft all throughout you probably got one of their cheaper 5150 cores that won't last 20K miles before wiping out and failing. The 8620 cores run $400+....just for future "watch-out" fyi!
To validate this point further as to the “McDonald’s environment” of which operate:
