Sponsored by: Innova
Subwoofer for Expd (EB)
Old Oct 7, 2003 | 01:28 PM
mtujohn's Avatar
mtujohn
Question Subwoofer for Expd (EB)
My niece blew out my 97's Expd (EB) subwoofer -- 8", 8 bolt hole pattern. I am having a heck of a time finding a replacement.
Any suggestions?
Also, my 6 pack CD player often does not load a cd correctly. I have to insert the cartridge a few times to get it load properly. Anyone seen that? Got a fix for it?
Old Oct 8, 2003 | 09:02 AM
PrPlayboy's Avatar
PrPlayboy
Try using a cd cleaner. The changer could just be getting worn out. What are the specs of that sub? What are you having trouble with, finding an 8 bolt pattern sub or matching the specs?
Old Oct 8, 2003 | 06:51 PM
mtujohn's Avatar
mtujohn
It is the eight hole bolt pattern that is the problem; I really do not want to go back to Ford to buy the OEM replacement.
As to the CD player, I have tried cleaning. Guess it is just wearing out. Started when someone 'slammed' the cartridge in; has not been the same since.
Old Oct 9, 2003 | 08:46 AM
PrPlayboy's Avatar
PrPlayboy
Than something is bent where the cartridge used to sit and now is allowing the cartridge to go past the normal spot.
If you can match the specs of the sub just drill new holes into the sub enclosure that match the new sub. You can use T nut on the inside of the enclosure to hold the sub in place. You will probly need to glue them into position so they don't fall out while threading the screws in. You can find T nuts at Home Cheapo. Here is a link that shows what they look like.
http://www.partsexpress.com/webpage....05584&desc=ASC
Because the encloser is plastic i would recomend the T nut for the inside.
Old Oct 10, 2003 | 01:56 AM
optikal illushun's Avatar
optikal illushun
upgrade to the JL stealth box...
03expedition79
Aug 4, 2014 03:34 AM
24kttop
Jun 13, 2010 05:18 PM
va98expd
Jul 25, 2004 09:07 AM
will4ya
Oct 22, 2001 10:18 AM
