1978 - 1996 Big Bronco
6" lift
Old Oct 7, 2003 | 12:39 PM
terrible1's Avatar
terrible1
6" lift
after a 6" lift is put on a 96 bronco what needs to be done to it, i.e. break lines or changing the angle of the drive shaft
Old Oct 7, 2003 | 05:08 PM
madmoose's Avatar
madmoose
well...
Driveshafts lengthened
New brake lines (which should come with any good kit)
Wheel and Steering alignment
Longer radius are a must at 6"
Kit should come with a wedge for the back axle to realign it's pinion angle.
Personally, at 6" lift I would highly recommend the superrunner steering assembly. It corrects all the steering problems that are inherent to TTB axles and made worse by lifts.
http://broncograveyard.com/products/...0superlift&sy=
maybe upgrade your brakes if you're gonna put big meats on it. like cross drilled rotors, disc brake conversion in the back.
If you haven't changed your gears for bigger tires, should do that too.
greystreak92's Avatar
greystreak92
35's, 4.56 gears, LS in front and a locker out back! Well thats what I'd do after a 6" lift. Then go put it through its paces way off the beaten path.
Most 4" and 6" suspension lifts require nothing but the stock rear spring angle blocks and extended brake lines front and rear. Best to check with the manufacturer of the lift you are purchasing to be 100% certain. Driveshafts are long enough. Front end will need a good alignment and possibly new caster/camber shims. Depending upon which lift you are looking at, certain manufacturers address alignment issues with the lift kit components.
Old Oct 7, 2003 | 05:24 PM
terrible1's Avatar
terrible1
i'm thinking about a superlift super runner kit
Old Oct 8, 2003 | 11:59 PM
85bigbronco's Avatar
85bigbronco
I was here a few weeks ago and I saw a rearshackle flip from a pro runner shop that gave about 5" and gave a corrected angle does any one know where it is are what the web site is
Old Oct 9, 2003 | 12:52 AM
BroncoRoadKill's Avatar
BroncoRoadKill
Is this the site your wondering about?
http://www.sky-manufacturing.com
There rear shakle kit is cool but it's a little pricey for me, I could just build my own mounts like theres for a fraction of the price.
Good luck bro.
Old Oct 9, 2003 | 06:48 PM
terrible1's Avatar
terrible1
thanks, my tires just came today, i'm so excited
Old Oct 9, 2003 | 07:54 PM
85bigbronco
thanks BroncoRoadKill thats the one.
Old Oct 9, 2003 | 08:13 PM
justshootme84's Avatar
justshootme84
I recently installed a 6" Skyjacker Class II suspension lift and 35" tires on my 84 Bronco. I have not had to extend the driveshafts or brake lines, but plan to in the near future just to be on the safe side. I strongly recommend getting the tubular, extended radius arms to make alignment much easier than with the factory arms and dropdown brackets. I opted for new lifted rear springs, but have a driveline shop check your pinion angle on the rearend to see if you need any shims and how many degrees. I just had to add a 1" block to get mine correct. Then get some steps so you and your passengers can climb in!!!
