360/390 perkolate problem
Old Aug 28, 2019 | 12:57 PM
customsport's Avatar
customsport
Hi Gents, Has anyone ever over come the after run hot soak percolation problems with the sister engines. both my 360 and 390 run with new alum. radiators and both perk the carbs and cause miserable hot starts unless let cool for 20-30 mins.
The 360 is stock 2300 carb and cast manifold. The 390 has an edelbrock 4 bbl, and an alum performer manifold. I mean less than 20-30 min possibly more cool off and it's foot to the floor and a long grind to finally get them to kick. Some times I even get a pop out the carbs on start up then usually a die-off cause no fuel till it pumps enough into the carb then normal run. I have started em on idle circuits as no foot feed and many times I get a start then the die after a short run requiring another long turn over to put fuel it the carb then we run normal. Get this one, once I got a back fire and blew off the welsh plug on top of the left booster venturi which happened 15 miles from home so the idle was shot and could hardly run.
got home and put in a new plug and cured that problem, now to see about the hot starts.......some times I retard the timing to get a faster spin once running I put it back to normal I dont get a back fire n it turns over faster.
Old Aug 28, 2019 | 02:01 PM
Brian1971f100's Avatar
Brian1971f100
Sounds like the gas is boiling in the carb. Common problem. You may need a phenolic carb spacer. This is just an image off google. you should order one for specific carb model. Good luck hope you get it resolved.
Old Aug 28, 2019 | 07:18 PM
SoCal69's Avatar
SoCal69
Those help alot I have one but I'm afraid today's gas boils at a lower temp than gas 40/50 years ago especially if running a mechanical fuel pump losing it prime , you can keep the mechanical fuel pump if you want and run a low pressure 2-3 psi elec fuel pump with it so it will never lose its prime again Holly has one several psi levels actually called a mighty mite . Run it from your tank line into pump then it will pump it into your mechanical fuel pump run a toggle switch if you only want to use it on hot soaks ...I run a 5-7 psi mighty mite from my aux tank needs no regulator blocked off the mech fuel pump section never had a problem again ...
Big Skier
18
Mar 31, 2008 08:07 PM
3ondatree
Jul 25, 2004 02:16 PM
thenitecrawler
Jun 7, 2004 10:04 AM
Shaneb75
May 18, 2004 10:16 PM
Boltgunner
Mar 20, 2004 02:11 PM
