Solid Axle Steering Question
Old Aug 27, 2019 | 11:30 AM
ewalt98's Avatar
ewalt98
My steering in my F350 4x4 got a little sloppy after I installed an RSK with SD springs. I'm pretty sure I never noticed this before...
What happens is when I turn right, the steering wheel stays cocked a few degrees to the right, and when I turn left, it returns to near center. I can feel a bit of slip just after I start turning.
Last night, I checked things out, and it turns out that the cross link (the tie rods connecting the front wheels) is rotating on its lengthwise axis, which is the slip I feel at the steering wheel. I can also manually rotate the tie rods, but I don't feel any excessive looseness.
All the steering gear was replaced a few years ago by me using Mevotech parts (I'm not sold on the quality, especially compared to Moog), so they don't have too many miles on them.
Also, the RSK didn't lift the truck more than 3/4", so I did not add a drop pitman link or change any other components outside of the springs and mounts.
Is this a normal sign of steering linkage wear, or does it sound like something else?
I am going to replace the tie rod ends.
Thanks
Old Aug 27, 2019 | 05:38 PM
ewalt98's Avatar
ewalt98
I'll answer my own question after some googling:
It is called drag link or tie rod roll and can be due to wear in the tie rod ends or excessive lift without using a drop pitman.
I must have enough wear for it to become noticeable after my RSK which netted less than an inch of lift.
Might look at a new drag link and a ruffstuff bushing called The Cure.
I was never really happy with the Mevotech drag link, which felt like rough metal on metal when rotating the tie rod after I installed it.
Old Aug 27, 2019 | 06:49 PM
Edgethis's Avatar
Edgethis
I'm getting ready to do an RSK myself. I looked up "the cure" from ruffstuff. It mentions that its designed for GM 1 ton tie rod ends. Will this work for us, too? Any modifications required?
Old Aug 28, 2019 | 09:57 AM
ewalt98's Avatar
ewalt98
From what I understand, the 1-Ton "cure" has a larger diameter bolt hole, so would likely squish around under pressure, likely leading to it bulging out.
There is a nice write up on powerstroke nation where a guy made his own.
Also, I think the Moog problem solver version of the right inner tie rod that has a rubber version of the "cure". I will probably get the Moog part, and see if the roll is cured, and if not, then look into making my own version of the "cure" to fit.
beersy50
Dec 12, 2023 12:17 PM
Stanislaw
38
Apr 23, 2015 01:48 PM
tacurt
Jun 26, 2010 05:49 AM
Medic 66
Jul 25, 2007 04:54 PM
amnesia_9
Oct 15, 2003 01:01 PM
