2014 F150 vibration
Old Aug 27, 2019 | 10:37 AM
LCPettingill's Avatar
LCPettingill
2014 F150 vibration
I own a 2014 F150 4X2 with 30,800 miles. About 3 weeks ago it started vibrating at 50 mph, easing off at around 67 mph. This didn't come on gradually but just started one day. The worn down tires were replaced with new and a 4 wheel alignment was done as well. The shaking was slightly better but still very noticeable. Took the truck to the dealer, the truck was test driven and then examined by a tech. Now I'm told I need a transmission mount and a new drive shaft. These parts alone total nearly $1200. Does this sound right? Again, this truck has under 31,000 miles on it.
Old Aug 27, 2019 | 10:39 AM
ford390gashog's Avatar
ford390gashog
Is this truck equipped with a two piece driveshaft? I assume you are past the 5 year warranty on the powertrain?
Old Aug 27, 2019 | 04:53 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
That it started suddenly tells me that something damaged it. Any recent trauma?
Old Aug 28, 2019 | 06:09 AM
cmorningstar01's Avatar
cmorningstar01
New transmission mount under $100
New driveshaft around $300-$400
You need to put your truck on a lift and examine the driveshaft and mount and figure out which it needs.
Sounds like the dealer is high especially for something that you can do yourself.
As the previous poster has indicated it sounds like some type of recent damage and not wear.
Judy Moreau
2009 - 2014 F150
34
May 1, 2018 06:43 PM
Adamjf78
2004 - 2008 F150
Feb 1, 2007 07:19 AM
binderzoo5726
1997 - 2003 F150
May 25, 2006 03:53 PM
RevAg12
2004 - 2008 F150
Feb 3, 2004 11:46 AM
billmayo
1983 - 2012 Ranger & B-Series
Oct 13, 2003 12:31 PM
