tss info
Old Aug 27, 2019 | 08:13 AM
hello113's Avatar
hello113
tss info
I have a 64 f100 with a 65 column in it with a 65 tss in it I know it will not work in the 64 wiring hookup but what I want to know will a c3tz-13341-b switch be made to work in the 65 column with a little modification ?
really don't want to hang a tss on the column with a hose clamp if I can help it thanks mike ,truck is almost ready to make a madden run around the block
Old Aug 27, 2019 | 01:30 PM
ibuzzard's Avatar
ibuzzard
See A Man About A Horse
I can’t answer that question, but have you considered just putting a 64 column back in there?
Old Aug 27, 2019 | 03:22 PM
hello113's Avatar
hello113
truck didn't come with one... it had a Lincoln column in it that was welded to a cut off shaft on the steering box unsafe looked like drunk chicken poop
but I put a cv ifs in the truck and a friend gave me a 65 column so in it went looks good in there but having a time with tss problems I have to work out
mike
Old Aug 27, 2019 | 04:09 PM
TA455HO's Avatar
TA455HO
Lead Gopher
I looked at the 1963/64 TSS on eBay and compared to my 1965/66 TSS and they do seem to be very similar. The main plastic piece as well as the cancelling cam look about identical. Hard for me to say they are identical without holding one in each hand, but there seems like a good chance it would mount fine.
Old Aug 27, 2019 | 04:42 PM
hello113's Avatar
hello113
thanks chad for the info !!! going to the salvage yard Friday and decode a few trucks and see if there are any 63-64 models and maybe snag a switch I'm going to take the 65 switch with me to see if they are the same mounting pattern if so I get lucky if not one of them ebay switches are going to be mine
mike
Old Aug 27, 2019 | 05:21 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The problem with the 1963/64 F100/250 C3TZ-13341-B TSS is, it's obsolete...no one has any NOS
Someone in this forum said he used C3OZ-13341-B TSS as a substitute.
This switch is 1963/64 Fairlane/Falcon/Comet, 1965 Mustang w/a generator.
1965's with an alternator, and 1966 Mustang is different: C5OZ-13341-B
C9TZ-13341-C (replaced C5TZ-13341-A & B) .. TSS / Obsolete/Reproduced, also available NOS
1965/66 F100/250 2WD / 1966 F100 4WD / 1967/68 F100/250 2WD/4WD & F350 / Ditto 1969 before serial number D96,001.
Old Aug 28, 2019 | 05:01 AM
User 71024's Avatar
User 71024
just curious, but why can't you use the '65 switch you have? I would assume I could wire it to work on any vehicle. It's obvious from your ifs that you're not going for stock.
Old Aug 28, 2019 | 07:42 AM
hello113's Avatar
hello113
I wish I could I can fallow a schematic but to modify it is beyond my skill level a lot of stuff runs through it
mike
Old Aug 28, 2019 | 10:06 AM
Crop Duster's Avatar
Crop Duster
mike
You just need to connect the wires. The 64 and 65 switches work the same. I just took a quick look at a 64 an 65 wiring diagram and the wire colors appear to be the same.
Old Sep 2, 2019 | 04:53 PM
hello113's Avatar
hello113
well I have a ebay nos tss awitch coming and also dc has them listed for sale but im sure they are from china
I hope o have a little hair left after I get it in and working
mike
Old Sep 9, 2019 | 07:50 AM
hello113's Avatar
hello113
a little update on the tss the 64 C3TZ-13341-B
worked in the 65 column no problems except the wires on it were they come out of the switch our on the wrong side of the stud where the rod screws in head to enlarge the hole in the plate so I could get the wires to switch sides and go down the column wire trap so they wouldn't rub on the rod and the color codes on the wires all matched up except on the road map it says one is red but there is no red wire but it was the last wire to plug in and the colors matched up with the plug
so maybe it will work thanks for all the help mike
David Guenther
May 6, 2014 01:09 PM
FirstTry
Apr 28, 2006 04:34 PM
pops-toys
Mar 23, 2004 06:19 AM
Joe403831
Mar 13, 2004 04:42 AM
64 f100
May 9, 2001 09:35 PM
