Best floor pans?
Old Aug 27, 2019 | 06:34 AM
mcline's Avatar
mcline
Best floor pans?
Finished rebuilding my bench seat and went to replace the original floor mat before reinstallation. My driver side floor pan was in worse shape than I had expected and now I’ll have to replace the floor pans. Seems a lot of folks carry replacement pans (DC, LMC,etc) but I was hoping that someone can point me in the right direction for the beat quality pans? Thanks in advance for any advice!
Old Aug 27, 2019 | 07:06 AM
lilorbie's Avatar
lilorbie
mcline Do Not use lmc for anything unless they are the only ones who have the part that you need. I used them for the bed replacement panels for my 67 f-100. if i had known how bad they were , i would have gone to the junkyard and had a bed floor cut out and been money and time ahead.
Old Aug 27, 2019 | 07:25 PM
mcline's Avatar
mcline
Sounds like LMC is out.. Thanks for the advice, lilrorbie! Anyone else have any recommendations?
Old Aug 27, 2019 | 10:14 PM
LACzar's Avatar
LACzar
Look here...https://tabcoparts.com/amfinder/ _ Tony.
Old Aug 28, 2019 | 02:04 PM
Brian1971f100's Avatar
Brian1971f100
I think I got mine form Dennis Carpenter of Macs. They were good.
Old Aug 28, 2019 | 04:23 PM
FuzzFace2's Avatar
FuzzFace2
Originally Posted by LACzar
X2 I used Tabco for the floors, rockers, cab corners, lower rear door posts and the lower inner & outer left door on my 81 F100 and was really happy with them.
They even called me to say some of the panels I ordered over lapped each other and did not need so & so part and would send a flat sheet to use as a filler if needed.
That was a plus to not need to spend extra money but I did order other parts I found later I needed.
just 1 side of what I did.
Dave ----
Dave ----
Old Aug 31, 2019 | 08:15 PM
T Henry's Avatar
T Henry
I bought two from Dennis Carpenter, they were good but after screwing one of them up I bought a replacement from Flashback F100's - Home. They are thicker than DC's.
I ended up buying my cab corners from them as well. Very sturdy stuff and I highly recommend them. No frills catalog, just a stapled together print out. The website is not fancy but LMC proves that doesn't mean anything.
Old Sep 1, 2019 | 10:09 PM
JoeKan's Avatar
JoeKan
I bought pre-formed floor pans for my 68 IH. I thought the thickness was sturdy and firm but didn't think they formed well. I think next time I do it, I'll get flat metal and form it myself.
RumbleFish13
1961 - 1963 F100 Unibody
Nov 19, 2011 01:35 PM
nisvec22
Sep 4, 2011 07:53 PM
taneum
Jan 20, 2009 12:30 AM
Hoosierman
Mar 31, 2000 03:08 PM
