DEF tank capacity
Old Aug 26, 2019 | 10:46 PM
Joezilla's Avatar
Joezilla
DEF tank capacity
I towed the MS Atlanta to the New Mexico mountains and back to DFW area with my F450 for a total of about 1500 miles including lots of day trips without the trailer. Upon returning to the DFW area, I started getting the "refill DEF tank message". I think it started with a number of about 500 miles to empty.
Anyways, I noticed on the gauge that it was about 1/4 full at that point. Having come from a Ram 3500, I was used to purchasing a 2.5 gallon SuperTech DEF container at Walmart and pouring that in. That amount usually filled me up. Today when I did that, I noticed that my gauge only went from about 1/4 full to about 5/8 full. I am guessing that it is a bigger tank than the Ram so I probably need to pick up another 2.5 gallons of DEF tomorrow.
I am LOVING this 450!!
Joe
Old Aug 26, 2019 | 11:34 PM
mrgrayaz's Avatar
mrgrayaz
The DEF tank is 7.5 gallons. I get about 250 mpg towing heavy.
Old Aug 27, 2019 | 08:03 AM
HRTKD's Avatar
HRTKD
Sometimes the gauge is a little slow to reflect the added volume of DEF. I wait for the gauge to get below half and then add a jug of DEF.
I don't track my DEF usage.
Old Aug 27, 2019 | 08:56 AM
Maximus216's Avatar
Maximus216
I pulled a 36 foot 5th wheel 4800 miles to Utah and back without adding DEF. You should get about 5000 miles on a tank of DEF
Old Aug 27, 2019 | 02:25 PM
wicked 2018's Avatar
wicked 2018
seems in line with what i am seeing on my 350 SRW
Old Aug 28, 2019 | 11:19 AM
homerj's Avatar
homerj
When I get to 1/4 tank I put two boxes in and seems to fill it up per gauge.
Old Aug 28, 2019 | 11:32 AM
wrvond's Avatar
wrvond
I find it perplexing that DEF comes in 2.5 gallon jugs and the tank is 7.5 gallons (which works out to three jugs of DEF from empty) but the gauge is marked in 1/4 tank increments.
When I look at the gauge I ignore the markings and mentally divide it into thirds which is a much more convenient way to track how much I have or need.
Old Aug 28, 2019 | 11:37 AM
67L48's Avatar
67L48
The 7.5 gallon tank is brilliant. Just wait until the warning comes on and it easily takes 5 gallons (2 x 2.5). No need to meter it out or to use the various filling lines that prevent spillage. Easy peasy. Done.
Old Aug 28, 2019 | 11:43 AM
wrvond's Avatar
wrvond
What came first, the 7.5 gallon tank or the 2.5 gallon jug?
Old Aug 28, 2019 | 12:21 PM
Joezilla's Avatar
Joezilla
Yep, I put in another 2.5 gallons of DEF last night, and it is full!! So when I get to 1/4 tank from now on I will know that it is 5 gallons down. That's good to know.
Joe
Old Aug 28, 2019 | 06:55 PM
MBaldo's Avatar
MBaldo
Exactly what homerj said. 2 - 2.5 Gallon Boxes fills up the tank when you are at 1/4 tank.
Old Sep 4, 2019 | 02:41 PM
RPFB's Avatar
RPFB
For a data point, I have a '19 F-450, 5100 miles on it with about 3000 of that towing a GD Momentum 397 weighing between 16.5K and 20K depending on what I had in it. I've had to add 7.5 gallons of DEF so far
Old Sep 4, 2019 | 03:48 PM
briangp's Avatar
briangp
Most truck stops have a DEF pump, if its convenient for ya. Half my gas stations here have them. Much much easier if you can pin one down, especially since you rarely need DEF.
Also, I've had my truck now for 24k miles (30K total) and I've only filled the DEF three times. Third time being just a few weeks ago, and I'm still at full.
Old Sep 4, 2019 | 09:03 PM
mrgrayaz's Avatar
mrgrayaz
It is directly based in fuel economy. Depends on how much you tow, and how hard - everyone is different, and I clearly use more then most
Old Sep 4, 2019 | 11:35 PM
briangp's Avatar
briangp
Haha, yeah I have alot of highway drives on her. Probably only 3-4000 miles worth of towing at the moment.
