200 ebp sensor
Old Aug 26, 2019 | 06:14 PM
mrwrench's Avatar
mrwrench
200 ebp sensor
why my truck break the ebp sensor ?
This is the 3rd sensor .....turbo is clean ....
also the turbo cycling when idling .... where to start?
thanks
Old Aug 26, 2019 | 11:22 PM
xcrsp440's Avatar
xcrsp440
Where are you buying these sensors? Some of the aftermarket brands don’t last long. Is the pressure tube cleaned out?
Old Aug 27, 2019 | 11:34 AM
npccpartsman's Avatar
npccpartsman
And the turbo cycling while idling is NORMAL PCM programming. It helps to "exercise" the turbo vanes to keep them free. AFA the EBP sensor goes, are you getting a code or what's going on?
Old Aug 27, 2019 | 04:36 PM
mrwrench's Avatar
mrwrench
I'm going to check codes tomorrow .... the last sensor was a Motorcraft .the tube is clean.......thanks
Old Aug 28, 2019 | 11:22 AM
mrwrench's Avatar
mrwrench
I scanned today , no codes , no MAP pressure .... I found the MAP hose broken .....now she run great again!! thanks all
Jsean Jackson
Jan 20, 2017 10:31 PM
Rod Jr.
Oct 4, 2014 08:43 AM
fixxxer-upper
May 30, 2013 12:21 AM
grantpage
Sep 17, 2011 03:45 PM
6LPSD
Feb 28, 2009 10:49 AM
