EFI swap
Old Aug 26, 2019 | 05:18 PM
Erika's Avatar
Erika
EFI swap
Hello,
I am looking to do an EFI to carburetor. I have a 5.8L 351W engine out of a 1991 F250 with an automatic trans.
My question is, is it worth it and is it possible?
Old Aug 26, 2019 | 05:25 PM
Killer79's Avatar
Killer79
Not worth it in my opinion. Why do you want to swap it out in the first place?
Old Aug 26, 2019 | 05:43 PM
Erika's Avatar
Erika
EFI swap
Because I prefer carb.
Old Aug 26, 2019 | 07:48 PM
Edgethis's Avatar
Edgethis
This has been discussed multiple times on here. There is no legitimate reason to downgrade to a carb. You'll spend more time/money converting it to a carb and tuning it then just fixing the efi system properly most of the time.
Can it be done? Anything can be done, doesn't mean it should.
Old Aug 26, 2019 | 07:58 PM
timbersteel's Avatar
timbersteel
I will try to help... read on it's positive
There's not a lot of reason to downgrade to carb, but some do prefer it. I personally hate it. I love EFI, and I don't miss the carb days in my teenage years, cold starting, or flooding.
There is a member Freightrain that converted his 300, I6 to carb. He loves it, and explained what was basically needed to do the swap regarding fuel regulator and pumps. This is mandatory since EFI runs higher fuel psi and you need it down to 5psi or 7. I can't remember.
Granted, it was the 300, but I'm sure it's posted numerous time here on how to convert the 302 or 351.
Let us know how we can help.
Old Aug 26, 2019 | 08:21 PM
Erika's Avatar
Erika
Thank you @timbersteel
@Edgethis for your replay to my question.
Would you guys know how to get some more power out of the 351 with out spending to much? Maybe something less than $100.
Old Aug 26, 2019 | 09:23 PM
EllieMae94's Avatar
EllieMae94
A basic tuneup. New plugs, wires, cap, and rotor. Advance the timing to 12°. Honestly not much you can do for under $100.
If you’re ambitious and already possess most of the tools you can get an upper plenum off a truck 302 and home port it to your lower. Check out Scndsin’s thread about it here:
https://www.ford-trucks.com/forums/1...d-project.html
Old Aug 27, 2019 | 12:25 AM
SPE's Avatar
SPE
Former Vendor
Yeah, $100 isn't going to get you anything substantial for power (and a carb swap won't pick up significant power by itself either and will cost WAY more than that).
1981 convert
Feb 9, 2016 08:52 AM
84f250mudder
Feb 6, 2011 05:30 AM
1993f1504x4
Oct 25, 2001 03:21 AM
