Engine Balance
Old Oct 7, 2003 | 11:05 AM
TxBandit's Avatar
TxBandit
Engine Balance
Is the 300 an internally or externally balanced engine? Also, what is the tooth count on the flexplate for a 3 speed automatic application? Does this engine have the same bellhousing bolt pattern as a 302?
Thanks,
Troy
Old Oct 7, 2003 | 12:04 PM
HardworkinFORD's Avatar
HardworkinFORD
Talking
Don't know the tooth count, but it is internally balanced and should be the same bolt pattern as the 302. Maybe someone who does a little more than I on the mechanical side can speak up.
Old Oct 7, 2003 | 05:18 PM
NM5K's Avatar
NM5K
I don't know if I would call it internally balanced. Maybe partly, but you still depend on the harmonic balancer on the front of the engine, and also the flywheel/flexplate holes are critical, and should only go on one way. Those are external balancing tricks, I would think. I think if you take the balancer off the front, the engine should run rough as heck. MK
Old Oct 7, 2003 | 08:08 PM
StrangeRanger's Avatar
StrangeRanger
The 300 IS internally balanced. What you are calling a balancer is a vibration damper. It has a zero imbalance. The bellhousing pattern matches the SBF but you cannot use the SBF flywheel because of the balance issue. As to the tooth count, I'm pretty sure Ford has used both 157 and 164 tooth flywheels with the 300 at various times.
Old Oct 7, 2003 | 08:58 PM
Silver Streak's Avatar
Silver Streak
I've been very sick for a few days and am kinda groggy, but wasn't the 157 tooth only used on the early Windsors with the 5 bolt bellhousing? Then they ditched the 5 bolt for the 6 bolt and used the 164 from then on. If that's the case, the 240/300 would have never had the smaller gear because it wasn't introduced at the time of the 5 bolt bellhousing.
Old Oct 7, 2003 | 11:34 PM
paulfix's Avatar
paulfix
The inline six is internally balanced as told above. this only applies if the crankshaft remains unflexed ( when under great load the crank can twist and thus cause the rotational loading to cause the engine to become unbalanced). THe crank on the 300 is plenty stong enough for this but a motorcycle I once had , a Honda CBX 1000cc six would bend the twist the crank and the engine would go from being silky smooth to very rough.
JB78f150
Jun 1, 2012 01:20 AM
bigdan1979f-250
Dec 7, 2011 06:44 PM
geo455
Feb 2, 2009 08:20 AM
vliposky
15
Apr 3, 2006 07:46 AM
vliposky
Mar 29, 2006 01:30 PM
