Front end racket
Old Aug 25, 2019 | 03:56 PM
bearintex's Avatar
bearintex
Front end racket
Front drivers side sounds like it is going to fall apart going over every bump. I have pushed and pulled on everything underneath there and can’t for the life of me find anything remotely loose. Ideas? Only 55k on it.
Old Aug 25, 2019 | 04:44 PM
Kapusta's Avatar
Kapusta
Loose air cleaner? It could be something loose in the engine compartment. I've had some bad noises from my F150 and it ended up being a loose jack rod.
Old Aug 26, 2019 | 09:02 AM
carbon coupe's Avatar
carbon coupe
Check your sway bar links. You have to unbolt one side to check it, its under tension just sitting there.
neilc88
Escape & Escape Hybrid
Jan 23, 2019 12:36 AM
xFordGurl
Oct 8, 2011 10:27 AM
fordf150farmer
1997 - 2003 F150
Feb 7, 2010 09:06 PM
CPerry
1997 - 2003 F150
15
Dec 15, 2008 07:24 PM
jrf250
15
Nov 13, 2008 08:46 PM
