1966 - 1977 Early Broncos
Cutting out in 3rd Gear
Old Aug 25, 2019 | 11:48 AM
Adam Todd Klein's Avatar
Adam Todd Klein
Hi folks, I just purchased a 1976 Bronco and need some help. The truck runs well until I run it for a while in 3rd gear. The Bronco starts to cut out - like a fuel filter issue - but I just changed the fuel filter and the issue is still happening. It’s episodic - sometimes it runs fine, sometimes it starts to cut out in 3rd gear. Any suggestions?
Old Aug 28, 2019 | 11:25 PM
EDC8008's Avatar
EDC8008
Could be the fuel pump itself going out, especially if it still as a stock style mechanical pump. These pumps are mechanically driven off of the engine and if the diaphragm gets old they loose vacuum and won't draw from the tank. Also need to look at the hoses and fuel lines them self, if the metal line has been hit it could be restricting flow. Any leakage in the suction line and low or now fuel flow.
If it does better when it's cooler out then it's most likely a pump issue. Cooler temps means denser fuel easier to pump, warmer thinner fuel and harder to pump.
Adam Todd Klein
Sep 10, 2019 05:43 AM
Curated Content Editor
General Automotive Discussion
Nov 3, 2016 12:20 PM
NewXer
2009 - 2014 F150
Jul 2, 2015 08:59 AM
r___r
All Things Towing
18
Oct 13, 2014 01:13 AM
