Broken COP M5 bolt
Old Aug 20, 2019 | 08:52 AM
Twonky's Avatar
Twonky
Broken COP M5 bolt
Over the weekend I changed my nearly 20 y/o spark plugs, COP's, and boots and I ran into a few problems. The COP in the #1 spot was already replaced but the plug was original. Who ever replaced the COP over tightened the bolt and it snapped while I tried removing it. There is a bit above the surface. I have tried heating it with my plumbing torch. I've tried the 2 nut technique for removing studs. I've tried grabbing onto it with vice grips. Nothing has worked. It's an M5 bolt and looks too small to use and easy out on. I don't have an acetylene torch or a welder. Any ideas on what to do next would be great!
Old Aug 20, 2019 | 09:55 AM
Kapusta's Avatar
Kapusta
That's likely to snap off as well if you're able to get a hold on it. It not too uncommon for steel bolts to get stuck when they're threaded into aluminum. It might be easier to cut off what's left flush with the manifold and then drill it out and retap it.
The easiest thing would be leave it as it is. The COP won't really go anywhere. The bolt nub will keep it place for the most part. You could wedge a toothpick in the COP hole against the nub. That would secure it a little better than nothing.
Old Aug 20, 2019 | 12:32 PM
Stewart_H's Avatar
Stewart_H
Originally Posted by Kapusta
The easiest thing would be leave it as it is. The COP won't really go anywhere..
^^^This.
Unless you can't sleep at night and you HAVE to remove it, just leave it. Years ago I ran my Lightning tens of thousands of miles and many years with a couple of COP's "rolling free" without any COP bolts to hold them down.
Stewart
Old Aug 20, 2019 | 01:39 PM
Kapusta's Avatar
Kapusta
The only trouble I've had with COPs was on my 01 CrownVic.. A few locking tabs of the electrical connectors broke off so they can work loose. The COPs themselves sit fairly securely on the spark plugs.
Old Aug 21, 2019 | 12:35 PM
Twonky's Avatar
Twonky
UPDATE!!! I got a hold of a welder and I welded a nut to the bolt stub and worked it out slowly. If I knew how easy it was gonna be to get the bolt out this way it would have been the first thing I tried!
Old Aug 21, 2019 | 01:03 PM
Kapusta's Avatar
Kapusta
I'm glad it worked out for you. I would have been leery of applying any kind of heat so close to a fuel line.
Old Aug 21, 2019 | 01:14 PM
Twonky's Avatar
Twonky
I won't lie, I was a bit scared. Since electricity takes the path of least resistance, I made sure to clip the ground as close to the bolt as possible and away from the injectors and fuel rail to guide the charge away and keep it from arcing in an unwanted area...like the fuel line . I also disconnected the plugs on the fuel injectors too.
Old Aug 21, 2019 | 01:23 PM
Kapusta's Avatar
Kapusta
I'd say you were quite lucky. I can see the slag on the lines and injector.
Don't break any more bolts like that.
cosmofennema
Jul 26, 2019 07:39 AM
DirtySCREW
1997 - 2003 F150
Mar 30, 2013 11:03 AM
rebel33382
Sep 16, 2009 08:30 PM
1Aauto
General Automotive Discussion
Aug 15, 2009 08:11 PM
mattselland
Modular V10 (6.8l)
Mar 12, 2007 10:42 PM
