Pretty much loaded,black on black with a 5.0 engine
You’re not going to find a Lariat with every feature available so yes, you’ll have to order one.
With that being said and if you’re concerned about cost, you’d be better off starting with a Platinum that has the 701A package and go from there because more than likely, it’ll be cheaper than a fully loaded Lariat with the 502A package.
You should go to the Ford.com website and build and compare a Lariat and Platinum that are fully loaded and at the end of your build, you can put out a search.
Pulled the information from dealer search. You are not giving enough information for anyone to help you. My search included 4x2 and 4x4 trucks. There was even a couple with sunroofs which are now discontinued if you want that. But be specific and look at the order guide.
