Torque specs
Old Aug 15, 2019 | 08:52 PM
TorqueyBrick's Avatar
TorqueyBrick
Torque specs
Hey all,
It's a 1989 f250 but it has 6 leaf springs and f350 was stamped into the stock riveted mounting gear all around.. idk why? and if that changes the specs but here it goes.
I've removed the rear leaf spring mounts( held on with rivets ), and old bushings in the leaf spring eye which was a PITA. I then made a homemade all thread press and got the new bushings in which was also a PITA 1/2 thread is needed at least. I'm ready with the entire new mount for both sides but I'm not sure what to torque the bolts to?
-Mount to truck frame?
-shackle to mount?
-shackle to leaf spring?
I've found diagrams showing 100ftlbs for the longer shackle bolts, but i'm not sure if its correct. I have found nothing on the bolts for the mount to frame situation.
Also should loctite be used on any of this ? (Thinking possibly the mount to frame bolts)
Thanks for any inputs !
-Steve
Old Aug 16, 2019 | 10:35 AM
sandymane's Avatar
sandymane
Here are the torque specs from my Haynes manual. I can't see where blue loctite would hurt anything. Sandy
Old Aug 16, 2019 | 11:18 AM
TorqueyBrick
Sandy,
Thank you for the specs! and the reminder that i do need a Haynes of my own which ill get this weekend.
Does anyone have advice on what to torque the spring mounts and shock mounts to the truck frame down to? (which i probably will be using loctite on if there is no issue with that).
-Steve
Old Aug 16, 2019 | 12:28 PM
Freightrain's Avatar
Freightrain
I would follow this for guidelines.
I don't typically use lok tite on bolts. Tightening them properly will hole them just fine without lok tite. Use of a lock washer would also work just fine. Though most don't use flange nuts/bolts, those frame brackets would be a good place to use them. They making self locking style.
super_duty_532
Jun 8, 2018 08:05 AM
ktm4012
Jun 26, 2016 05:31 PM
dzlfumes
Mar 4, 2010 12:18 PM
Franken-Truck
Jul 18, 2005 09:57 AM
51dueller
Apr 18, 2003 07:55 PM
