I have a 1995 F150 that I replaced the turn signal lights on. Passenger side indicators work perfectly fine but driver side does not work when I turn left. When I use the hazards they all work. Any ideas?
Does it lock down like it wants to work and just no blink? Or does it blink and not shut off? Did it work before the swap? Does the driver side work when you turn right? Sandy
Yes it does lock down and has no blink. It did work before the swap. The lights do turn on all sides when all lights are on
See if both of your rear brake lights are working with no other lights on. After you do that see if your rear light blinks when you engage the turn signal right.
