which flywheel do I use on this contraption?
Old Oct 6, 2003 | 11:09 PM
Ryan356's Avatar
Ryan356
I am in the process of converting my 88 f150 to manual transmission. I need to get a flywheel but dont know which one to get. The motor is a 351W efi. I am using a np435 tranny from a 72 f250 which I have a bellhousing for from a 78 truck. So my plan was to use the 72 np435, put the small block bellhousing on and use some clutch pedals from a 78 ford f150. I want to also use the lever clutch engagement setup from the older 78 trucks. So can I use the flywheel from a '84 or around there? I saw on the online junkyard that some of those eras came w/ a 351w/np435 combo. But were they lever actuated clutches...is the clutch going to have to be from that era too? Hydraulic clutches are different arent they(the actual clutch). It has to be the kind that will except the arm that pulls the clutch back. I hope someone can help. Thanks in advance.
Ryan C.
Old Oct 7, 2003 | 09:56 AM
gatesj's Avatar
gatesj
About the only thing I can help with is that I know the 351w always has to have a 28oz balanced flywheel... If you get one off of a 351w or a 82 or earlier 302 it should work, assuming it's right for the clutch assembly.
