flat 8 numbers
Old Aug 11, 2019 | 10:50 PM
CJ21's Avatar
CJ21
flat 8 numbers
My F68 has a flat head 8 that is stamped made in Canada 8BA. The firewall tag provides the Engine number 8J-1008
I have been researching the engine and getting mixed results.
First, is this a 1948 engine as some data suggests the 8BA was a 1949 engine and that the truck should have been labelled an 8RT (I know they are essentially the same)?
Does the engine serial number tell me anything more?
Old Aug 12, 2019 | 12:40 AM
mtflat's Avatar
mtflat
8 says it was 1948 239 late series engine
J means it came with the 4 spd trans
8RT was just a designation on some accessories - heads for instance
The 8BA series started with the 48 trucks, Jan 16, 1948
That's about all there is to know.
Old Aug 12, 2019 | 03:10 PM
firstrider's Avatar
firstrider
8RT is a heavier cast truck engine . Weighs 570 lbs.
Old Aug 12, 2019 | 09:18 PM
mtflat's Avatar
mtflat
Where do you get that info? Just curious cause I've never seen that published.
All 8RT/BAs weighed 569
Earlier V8s listed at 525
I wonder if you're thinking of the 337 flathead from F7 and F8 trucks. I've heard it weighs a couple hundred pounds more...
Old Aug 12, 2019 | 10:06 PM
ALBUQ F-1's Avatar
ALBUQ F-1
There is no such thing as an 8RT block, they are the same as 8BA's. 8RT heads have a little thicker deck surface, according to some sources.
fordf350camper
Dec 5, 2008 02:35 AM
51f-1fan
19
Dec 6, 2006 10:41 PM
Christopher2
Jul 11, 2004 01:37 AM
rogerf100
Jul 15, 2002 05:53 PM
skeleton
Flathead V8 & Flathead 6
Jul 10, 2002 07:38 PM
