Modified Camshaft
Old Oct 6, 2003 | 09:34 PM
keyboardcowboy16's Avatar
keyboardcowboy16
Lightbulb Modified Camshaft
I have a shortwheel base F150 with a fresh 302 bored over .008, 2 barrel carb and stock firing and intake. The ignition, carb, and intake are coming off. I need ideas for a cam. Nothing too radical, still slightly a daily driver by choice but i would like something around 1500 rpm. Advice appreciated
Old Oct 6, 2003 | 10:22 PM
fordzman's Avatar
fordzman
comp 4x4 torque monster cam, performer intake and a holley four barrel carb. headers would'nt hurt..
Old Oct 7, 2003 | 03:04 AM
Torque1st's Avatar
Torque1st
Posting Legend
Moved to proper forum.
Old Oct 7, 2003 | 07:11 AM
jwtaylor's Avatar
jwtaylor
Are you saying the engine was bored .080 or .008? Weather you need a 4X4 cam or not I cannot say however give comp cam a call and let them point you in the right direction. Do this call them say 3 times over a weeks time, you think I am crazy but I have called and received two different recommendations however they were close just not the same one, go with the one they recommend the most. You will more than likely be told you need a comp extreme 4X4 or an extreme energy either way let them decide the lift and duration after you give them your specs. Later, good luck
brandonnichols
Jan 2, 2014 08:23 PM
Lumpy78
May 4, 2010 11:25 PM
Powergod
13
Mar 26, 2004 03:33 PM
donnachie
Nov 9, 2002 05:03 PM
David
19
Jan 29, 2000 08:01 PM
