Front Dana 60 upgrades?
Old Aug 25, 2019 | 07:00 PM
GNR22's Avatar
GNR22
Originally Posted by BillBraskey
Thanks very much for the detailed reply. I will probably PM you with further questions soon.
I am a big fan of rebuildable balljoints. I know Moog is known for making good stuff, but over the past few years there has been a drop in their overall quality because they have accepted substandard materials/subcomponents from less reputable suppliers in Asia and Eastern Europe. I do not know if this has affected the specific Ford parts we are talking about, but it has been an issue for Volvo and other European marques.
I have manual locking hubs and wouldn't have it any other way. They are stock Ford hubs. Since I will be refurbishing everything from the axle housing outboard, I will look into the Warn options; I have good experience with Warn products and their tech support. Before you mentioned this, I was planning to use a couple of small modifications to the stock hubs that I found while going down interweb rabbit holes.
I am wary of correcting this particular "weakness". Something must be the weak link in a driveline. It is best that the weak link be the easiest and/or cheapest to repair. I would prefer that a halfshaft--especially the outer end--break rather than the diff or something else upstream. What are your thoughts on this philosophy as it relates to this specific axle/truck?
The steering linkage is quite worn and will be replaced soon. I will probably post a new question later regarding my options there.
I was already going to replace it. I find it atrocious that any differential cover doesn't have a drain plug. It seriously should be illegal. Instead of our nanny government requiring back-up cameras and lane departure warning, why not start with requiring zerk fittings and drain plugs? The absence of a drain plug is to me the most obvious sign that the manufacturer has cut corners in at least one other area as well, hence the whole reason for my thread in the first place.
This is also atrocious. I discovered this when removing years of grease and red clay from the undercarriage. I found several vendors of retrofit seals. Are there any to avoid?
Lockers are a component I have no first-hand experience with. A close friend, whose technical expertise I trust, is a big fan of air lockers (i.e., ARB), but his vehicle was already equipped with an air system from the factory. I prefer a more manual and robust system, if possible. It sounds like the Detroit is similar to the Quaife-style LSD. I don't want an LSD, per se. I want to be able to isolate a single wheel on my command. For example, If I snapped one of those 19-spline halfshafts....
I have not had a single "premature" failure on a Moog balljoint over the course of any of my trucks lives. I have never had one that didn't outlast the mileage on the joints that came from the factory. If you are more comfortable with a rebuildable unit from a different manufacturer, by all means go ahead and use one of those.
The 19 spline axle shafts are indeed the weak point as the axle sits from the factory. Next weak link is either the open front differential carrier, or the pinion yoke on the front axle. I would also rather replace a stub shaft than a carrier or yoke.
As far as outer axle seals, I only have experience with the ones I listed the link for. I know that those will work and have not searched anywhere else for a different seal.
I had to look up the "Quaife" limited slip unit to respond to this. Yes, its a torsen unit like the Quaife. The advantage to one of these is that it tends to put power wherever you have the most traction. The only exception to this is when one tire is up in the air. And if that happens, you can tap the brake pedal and touch the gas and it will trick the unit and put power back to the wheel on the ground. So if you broke an axle shaft, you could potentially ride the brake in any situation that you need more traction and keep the truck moving forward. But as somebody with experience with lockers front and rear on a truck, I can tell you first hand that a locker will nearly remove your ability to steer while the front is locked together. It just wants to go straight. A limited slip unit, such as a torsen unit, will let one wheel spin faster to maintain your ability to steer. You also never have to worry about maintenance on it beside fluid changes, as there are no air lines that are prone to failure, and no clutches to fail. If you are hell bent on a selectable locker, I would strongly recommend an Eaton E-Locker vs an air locker.
nogo73
Offroad & 4x4
13
Jun 16, 2016 11:36 PM
rrawlins
16
Dec 11, 2011 05:33 PM
deisele75
18
Mar 9, 2007 08:00 PM
mjl351w
Jun 2, 2004 11:08 AM
