4.9l f150 overheating
Old Aug 9, 2019 | 12:00 PM
Daniel Hedge's Avatar
Daniel Hedge
Been having issues with a 95 f150 with the 4.9l overheating. After driving about 60 miles I heard the coolant boiling. It was boiling out of the overflow tank. It was rust brown in color. I flushed the system, replaced the cap, thermostat (it’s correct position), and replaced the water pump. Still overheated after about 10 miles. I decided to go ahead and replace the head gasket even though I didn’t have any blown head gasket symptoms . I don’t have any hoses leaking or collapsing. Fan clutch seems to be working correctly. After all of this I still have coolant boiling over after 15 to 20 miles drives. Any ideas?
Old Aug 9, 2019 | 12:55 PM
yellercat's Avatar
yellercat
Hey Daniel, I would take an air hose gun and reverse blow the radiator out to see what comes out. It could be clogged. Have to blow my tractors out all the time that way. Check your brakes and wheels for drag. Have had vehicles mechanically drag the entire truck to even overheat the system. Otherwise, your radiator may be suspect. They can be flushed at a radiator shop or replaced if so, depending on your circumstances. Luck with it, you'll find it!
Old Aug 9, 2019 | 12:58 PM
sandymane's Avatar
sandymane
My mechanic said you probably need a new radiator. You can get a harbor freight thermal thermometer and test it from top to bottom.. Sandy
Old Aug 9, 2019 | 01:36 PM
ZombieF150's Avatar
ZombieF150
"My mechanic said you probably need a new radiator. You can get a harbor freight infrared digital thermometer and test it from top to bottom.. Sandy"
Fixed it for you buddy. @sandymane
Old Aug 9, 2019 | 02:53 PM
sandymane's Avatar
sandymane
Thanks bud. Sandy
Old Aug 9, 2019 | 03:59 PM
Phase3's Avatar
Phase3
Could be a few other things also... clutch fans go bad where basically you can stop the fan with a rolled up magazine even when the engine is hot and fan should be nearly solid.
Thermostat can stick closed and system will get hot pretty quickly. Youll be able to feel the thermostat open at 192 degrees by holding on to top radiator hose.
Old Aug 9, 2019 | 05:51 PM
ZombieF150's Avatar
ZombieF150
are you sure you got all the air out of the system? I would first suspect the radiator if the air was out of the system. I bought a funnel that connects to the radiator where the cap goes that made a heck of a difference when trying to purge air from the system. Absent that, get the nose up in the air on ramps or jack stands and see if it is air trapped.
Old Aug 9, 2019 | 05:53 PM
ZombieF150's Avatar
ZombieF150
Originally Posted by sandymane
Thanks bud. Sandy
No worries
Old Aug 10, 2019 | 03:45 PM
WolfMann's Avatar
WolfMann
Had a similar problem when i first got my 90 f150, turned out to be gunk clogging up the radiator. Next time it gets warm shut it down and feel the radiator on the fan side, if it's hot top and bottom but cool in the middle you should have a better idea.
Old Aug 10, 2019 | 03:48 PM
WolfMann's Avatar
WolfMann
Also I would test for combustion gases in the coolant before swapping the head gasket. I think the consensus is that's not a common failure on the 4.9. You should be able to rent a tester from any auto parts store, think they sell them online too, don't forget the blue test fluid.
