Sponsored by: Real Truck
Trailer light problem
Old Aug 9, 2019 | 11:20 AM
3Weimies's Avatar
3Weimies
I'm new to the F250, we bought a 5th wheeler. I plugged light connector into factory socket. Trailer brakes and running light are good. No turns or brake lights. In my searching, I seem to find a setup for RV wiring as well as utility/cargo wiring. Is there an adapter I can install on the truck ? Suggestions or advice please !
Old Aug 9, 2019 | 11:41 AM
Just Strokin's Avatar
Just Strokin
There is a 7 pin bed harness kit you can buy. I am assuming this is what you are asking about.
Bed 7 pin harness
BC3Z-13A576-A
https://www.ebay.com/sch/i.html?_fro...576-A&_sacat=0
You may or may not have the connectors on the frame in the area of the driver rear tire.
Old Aug 9, 2019 | 12:16 PM
3Weimies's Avatar
3Weimies
Thanks, I have all that, bed connector is installed. No turn signals or brake signal at either connector. I am right now looking further along the chassis harness for issues. The towing signal relays in the main fusebox are new. Have not found any bad fuses. My ground at connectors is good. It has to be something common...… I am trouble shooting right now,,,,
Old Aug 9, 2019 | 02:22 PM
3Weimies's Avatar
3Weimies
Problem Fixed. Found another related fuse blown. All lights work now !
