2004 axles
Old Aug 9, 2019 | 07:07 AM
Dtbarton's Avatar
Dtbarton
2004 axles
I'm putting 2004 axles under my 97 f250 4x4. Was wondering if anybody has an idea how long it would take per axle? I'm having it done. I have all the right springs for the job.
Old Aug 9, 2019 | 08:17 AM
knottyrope's Avatar
knottyrope
https://www.ford-trucks.com/forums/1...y-white-6.html
can ask how long it took him to do it but he did a bit more than just axles
Old Aug 9, 2019 | 08:54 AM
humphrey169's Avatar
humphrey169
04 supetduty? That's a leaf spring axle. Did you mean 05?
Old Aug 9, 2019 | 10:05 AM
Dtbarton's Avatar
Dtbarton
No, 04. Leafs front and back. Thanks
Old Aug 9, 2019 | 10:10 AM
knottyrope's Avatar
knottyrope
so its just an RSK add on for front?
Could be a day job unless there is issues.
Old Aug 11, 2019 | 09:30 AM
Edgethis's Avatar
Edgethis
As mentioned, it shouldn't take long at all. The rear is a direct swap and the front just requires an RSK. You may have to check driveshaft length, I'm not sure.
You are aware that you will need new wheels with the metric lug pattern I hope.
Old Aug 12, 2019 | 01:51 PM
Dtbarton's Avatar
Dtbarton
I have 2002 Ford Harley rims for it. Thanks!!
Old Aug 13, 2019 | 03:45 PM
dclack's Avatar
dclack
SD rear leaf springs use bigger bolts, so you will need to drill out your hangers.
Old Aug 19, 2019 | 08:45 PM
humphrey169
Done yet? Rockin and rollin?
Old Aug 20, 2019 | 12:33 PM
Dtbarton's Avatar
Dtbarton
Waiting on tbe rsk
