Tips for Rotating Tires Myself
Old Aug 9, 2019 | 11:04 PM
Blazn's Avatar
Blazn
Since we're talking stores
+1 to Discount tire
If you have Sam's Club membership they also offer free rotation. Probably not the solutions you were looking for.
Old Aug 10, 2019 | 06:51 AM
2019er's Avatar
2019er
Originally Posted by finnf250
I know this isn't what you asked, but I take my truck to the local Discount Tire. They offer lifetime rotation and balance for $120 on tires you don't buy from them. Free if you buy tires from DT.. I just have them do the work while I grab lunch. I calculated I will pay $12/visit ($120/10 visits per tire life time). Well worth it.
+1 discount tire.
Once I need my first set of tires, or a replacement, I go there and get the certs.
Old Aug 10, 2019 | 06:58 AM
duckduke's Avatar
duckduke
I realize I have 6.2 and costs are slightly different for oil change, etc ........ But
I usually do all oil changes and any other work myself and did first 2-3 oil changes myself. Hate letting a dealer touch my truck.
But, when I found out they would change oil/filter and rotate tires for $54 I got hooked. I just go t Quick Lane at the dealer and I don't think I've ever waited over an hour (usually wait about 30-45 min). They torque wheels on, etc. So far I haven't found anything that they've screwed up (which is rare).
Also .... Questioned dealer on rotation. Their recommendation on these trucks is simply front to rear and rear to front. I have 56,000 + on factory Goodyear Wranglers and still have 6/32s tread and even wear. I should make about 65,000 no problem.
Just FYI.
Old Aug 12, 2019 | 06:11 AM
bjones211's Avatar
bjones211
Thanks for all the input! I think I'll do my own oil but let Pep Boys or Discount Tire handle the rotations.
Old Aug 12, 2019 | 08:13 AM
BocaIvan's Avatar
BocaIvan
Agree with others, changed my oil yesterday, going to Costco today for a tire rotation, $28.
Old Aug 12, 2019 | 09:15 AM
Flyct's Avatar
Flyct
FTE Community Team
Originally Posted by bjones211
After experiencing my first dealership oil change and tire rotation I plan to start doing it myself from now on. They charged me $175 for conventional oil and when I asked what it would be for full synthetic they wanted another $155 ! Checking the price for 15 quarts of Motorcraft full synthetic oil on Amazon the price difference was $40. (Have a 2019 F-250 - I know it takes 13 quarts) I guess they think they can justify almost 400% profit... I wouldn't hesitate to do it myself except for the tire rotation hassle.
My question is what are people using for jacks and stands to get these tall trucks up in the air? Are there any tricks or tips people have?
If you want a record at dealership for oil changes bring your own Valvoline PBE synthetic oil or Rotella T6 purchased from Amazon with you to dealership and have them change it. Or local tire store only charges $12 labor to do oil/filter changes if you provide the oil and filter.
But I’m 72 years old with a bad back and I still change my own oil and filters. I have a Fomoto drain valve which makes it easy and relatively no mess. Changing oil on a Superduty is not physically difficult. I do it on the grass. I lay a large piece of cardboard down to slide under the truck. No jacking required. If there are any oil drips it doesn’t stain the driveway.
For tire rotations I use local tire dealer. These tires are heavy for me at my age and bad back. I can make an appointment and they are always on time. Plus they have a bright clean waiting room with large screen TV, soda, coffee and snacks. I even bring my dog with me. For $12 labor fee and $5 tip to the tech it’s well worth it for me. They rotate the tires, inspect the brakes, air the tires up properly and reset the TPMS sensors system all for $12. I just had it done last week. I watched as he verified the 60/80 PSI tire pressure and torqued the lug nuts to 165 lbs per my request.
Old Aug 12, 2019 | 03:54 PM
cficare's Avatar
cficare
Originally Posted by Flyct
If you want a record at dealership for oil changes bring your own ...
Just in case you didn't know, anyone can record their "owner performed" maintenance work on Ford's website at https://owner.ford.com/ and have it available to all Ford dealers.
Old Aug 13, 2019 | 06:31 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Jack front axle up, put jackstands under it.
Move jack to rear and raise from differential.
Rotate tires.
Reverse procedure to lower truck.
Done.
Old Aug 13, 2019 | 07:49 AM
khensley's Avatar
khensley
Just FYI.
Agreed.....I do trust the local dealer to manage to change the oil and rotate the tires (that's about it), and it's done very easily....and cheaper than if I paid myself $15 per hour to do it.
Old Aug 13, 2019 | 09:43 AM
USSenator's Avatar
USSenator
I jack up and support both rear wheels with jack stands. Then do each front wheel separate with a jack. No front support, as it's quick and I'm not under it. Check/inspect the disc brakes at the same time.I have a 3-Ton floor jack. I use a impact wrench, and a T-handle for final tightening once it is 100% on the ground.
When I put the tires back on, a shovel really helps to lift the tire into place. Those things are too heavy otherwise.
Easy peasy. Faster than bringing it to a shop.
Old Aug 13, 2019 | 08:57 PM
Northern Explorer's Avatar
Northern Explorer
Trailering
Tire rotation video
I made a video that might help.
Old Aug 13, 2019 | 09:15 PM
AndyErson's Avatar
AndyErson
One thing I do to minimize vibration is to start the first lug at the bottom while you hold the tire in with your foot. Then snug up all lugs by HAND while pushing and pulling on the tire to have it seated as strait as possible. Then torque in proper cross pattern to spec. I've had tire shops get impact happy and the wheel isn't properly on the spindle.
Old Aug 14, 2019 | 07:11 AM
  #28
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Originally Posted by Northern Explorer
I made a video that might help. F250 Tire Rotation and TPMS Reset
Why did you lock your hubs?
Also, why anyone would use the factory jack vs. a floor jack is beyond me...
Old Aug 14, 2019 | 07:15 AM
  #29
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
And don't forget to use a wire brush on the mounting surface and hub to clean off the rust & dirt. Apply anti-seize to the mating surfaces between the hub and wheel.
Old Aug 14, 2019 | 09:09 AM
  #30
Northern Explorer
Trailering
delete....
Last edited by Northern Explorer; Aug 14, 2019 at 12:12 PM. Reason: duplicate post
