A\C not blowing hard
Old Aug 8, 2019 | 11:00 PM
Matheny6.0/2005/EX's Avatar
Matheny6.0/2005/EX
05 Ex 6.0 Diesel, blower works, actually was replaced, all speeds of fan work, a/c air is cold as hell. Speed of air coming out the vents is lacking. Was really hard, then just seemed to fade away (over about a 3 day period). To can maybe fill it about 8-10 inches from vent on max air. Like I said earlier, everything else is working great, anyone have any suggestions on how to fix?
Old Aug 8, 2019 | 11:27 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Check your blend door for it being stuck...is any of it coming out the defrost since this happened? Maybe split between vents and defrost or floor?
Old Aug 8, 2019 | 11:30 PM
Matheny6.0/2005/EX
I can switch from defrost to floor to face level, all will blow out at the same speed as stated earlier. This is why I’m confused 😐
Old Aug 9, 2019 | 08:22 AM
alloro's Avatar
alloro
The evaporator core could be clogged with debris that is preventing air from passing through it.
