High Oil Temp Question
I've recently installed the International water pump for our trucks with the filter and changed to the 203* thermostat. I am now seeing sustained oil temps of 217* with no load, regular driving and ambient air temps of 90*ish.
I've read all the high oil temp threads on here and understand that 217* isn't out of the norm (I used to run 195*-210*). But I did come across the idea that the 203* thermostat might not be the ideal one for our trucks and that the 195* is the better one to run with.
So my question is; which thermostat to use, the 195* or the 203*?
Thanks for any input!
I too switched to the IH water pump with the 203° thermostat and saw similar temperature increases like you did. I did a lot of research and found out the increase up from the 195° thermostat is negligible and how the engine was designed to run by International.
You can actually get a short stem thermostat for the IH pump all the way down to 182° I think, maybe it was 185°.
I saw temperatures near 220 and 225 occassionally when running the truck hard in the dead heat of summer, but again those temperatures are nothing to be concerned about. Keep an eye on it if you like, but the temperature is safe to run in that range. Now if it started to get up to 250°, I would consider looking at possible problem areas. Even then, synthetic diesel oils like 5w40 and 15w40 are safely rated for higher than that.
There is quite a bit if information and discussion on this topic, but I have summed it up for you for the most part.
I have a couple of part #'s noted on my "7.3 Wish List" of parts and they are as follows.
481828 or 1845804C2 or 1845804C1
I had the OEM thermo from Ford on my '99 with dual Terminator HPOS and had to swap it out for the Termy made 180* because of the extra heat the dual pumps created.
Previous thread for more info: https://www.ford-trucks.com/forums/1...l#post10768402
Stewart
Stewart
Do you suspect that had an impact on your recent coolant leak/head mystery recently?
Why I changed back to a Ford OEM 7.3L thermo was due to the extra heat that grew to more than I was comfortable with when I was towing our travel trailer, or in weather with high temps while unloaded.
As for if it contributed, who knows. I understood I was shortening the life on my engine when I started modding it. Sure, I thought it would last longer than it did, but I went in with eyes wide open.
Stewart
built cooling system, if anything gets even close to hot there is usually something mechanically wrong.
International has built a ton of these motors in every thing you can think of, and I bet they are all at 203-deg. I would think that they
know better where the motor should be running than us (or Ford) guessing where it might be better. Cooler isnt always better.
Could be that Ford had a temp sensor that worked better 8-deg cooler and it was cheaper to just use a different thermostat than design
a new sensor. Engine just had to last 100K miles so go for it.
My truck had a broke thermostat I found when changing out the old water pump, so this isnt a great comparison.. BUT.. With the new pump and the
203 it has much more power, is more quiet, lower EGT, and gained 2-MPG. This from just getting the engine heated up. Now the temp gauge always
read fine and the heater blew good heat. That old thermostat was broken for years as the truck hasent gotten great milage for as long as I can remember and
has been, noisy especially in winter, for a real long time.
i recall reading how the t444e equiped in street sweepers came equipped with a 203* to keep heat up, help atomize the fuel since rpms werent there..etc, and thats how the 203* came to light for our trucks so, members ran with the idea..
