Sponsored by: Auxito
Parking brake adjustment
Old Aug 5, 2019 | 12:44 PM
1999-F150's Avatar
1999-F150
I need to tighten my parking brake. I see the adjuster on the drum but I do not know which way to turn it to tighten it. Any help would be great. Thanks
99 F250 4x4 5.4 3.73
Old Aug 15, 2019 | 04:15 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Turn it the way the lever will allow to go tighter.
Old Aug 30, 2019 | 11:58 PM
Wes_V10's Avatar
Wes_V10
1999-f150,
I just did this on my own 1999 f150. On the driver's side I had to push upward on the teeth of the adjuster to tighten the brake. Not sure about the passenger side as I haven't had to mess with it or taken the rotor off to see how the screw is oriented.
If you live in a northern state you may want to check that the lever where the brake cable connects on the back of the dust shield can move freely. These are notorious for rusting solid in my neck of the woods.
Good luck,
Wes K.
Old Aug 31, 2019 | 10:16 AM
alloro's Avatar
alloro
According to the FSM, the correct way to adjust the parking brake shoes is to measure the inside diameter of the drum and then adjust the outside diameter of the shoes to be .5 mm (0.020) less than that.
Old Sep 5, 2019 | 12:35 AM
Lime1GT's Avatar
Lime1GT
That would only work if the rotors are new without a rusty lip to try and fit over the adjusted shoes.
hillbilly1989
Jan 18, 2018 11:03 AM
Nightintruder
Nov 29, 2010 07:27 PM
idealtrucks
2004 - 2008 F150
Jan 17, 2010 03:09 PM
homer4111
Feb 10, 2006 07:39 AM
ckstrawser
Feb 8, 2004 12:50 AM
